MHB S8.5.1.64 values of m for region
  • Thread starter Thread starter karush
karush
MHB
$\tiny{s8.5.1.64\p364}$
For what values of m do the line $y=mx$ and the curve $y=\dfrac{x}{x^2+1}$ enclose a region.
Find the area of the regionok I could only estimate this by observation but it looks $m\ne 1$
not sure how you solve by calculation
both functions are odd (symmetric to the origin) and pass through the origin. the curve is also asymptotic to $y=0$.
$\dfrac{d}{dx} \bigg[\dfrac{x}{x^2+1} \bigg] = \dfrac{1-x^2}{(x^2+1)^2}$
at the origin, the slope of the curve equals 1, therefore $y=x$ would be tangent to the curve.
so, to intersect the curve to form closed symmetrical regions in quadrants I and III, the slope of the line must be $0 < m < 1$
ok that helped a lot
Since the problem says "enclose a region" I would just see where they intersect:
$mx= \frac{x}{x^2+ 1}$
An obvious solution is x= 0. If x is not 0 we can divide by x to get $m= \frac{1}{x^2+ 1}$. Multiply both sides by $x^2+ 1$ to get $m(x^2+ 1)= 1$. If m= 0 that is impossible and as long as m is not 0, divide both sides by m to get $x^2+ 1= \frac{1}{m}$. Subtract $1$: $x^2= \frac{1}{m}- 1$. If m> 1 there is no such x. If m< 1 $x= \pm\sqrt{\frac{1}{m}- 1}= \pm\sqrt{\frac{1- m}{m}}$ so the lines cross in three points and enclose two regions. The answer is "all m less than 1" not "all m except 1".
for $x > 0$ and $0 < m < 1$ ...
$mx = \dfrac{x}{x^2+1} \implies x^2+1 = \dfrac{1}{m} \implies x = \sqrt{\dfrac{1}{m} - 1}$
Sum of the areas of both regions in quads I and III ...
$$A = 2 \int_0^{\sqrt{\frac{1}{m}-1}} \dfrac{x}{x^2+1} - mx \, dx = m - (1+\ln{m})$$
well pretty valuable to know that...
For original Zeta function, ζ(s)=1+1/2^s+1/3^s+1/4^s+... =1+e^(-slog2)+e^(-slog3)+e^(-slog4)+... , Re(s)>1 Riemann extended the Zeta function to the region where s≠1 using analytical extension. New Zeta function is in the form of contour integration, which appears simple but is actually more inconvenient to analyze than the original Zeta function. The original Zeta function already contains all the information about the distribution of prime numbers. So we only handle with original Zeta...
