Salt bridge and electical field
In a Galvanic cell, the presence of a salt bridge is essential for maintaining electrical neutrality between the two half-cells, preventing the buildup of an electric field. This leads to the conclusion that, ideally, the electrical potential difference between the solutions in the half-cells is zero. The discussion also touches on the concept that the solutions and the salt bridge act as conductors, where the electric field within a conductor is zero, ensuring equilibrium. Furthermore, it is possible to calculate the difference in electrochemical potential between the solutions, focusing on the solutions rather than the electrodes. The conversation highlights that Galvanic cells can be configured in various ways, including setups with two electrodes in a single electrolyte solution, which can enhance voltage measurements by minimizing junction potential errors.
wnvl2
Is it correct that a salt bridge in a Galvanic cell makes that there is no electrical field between the solutions of the two hallf cells? Does that mean that the electrical potential (I do not write electrochemical potential) between both solutions is zero in an ideal world?
Is it also possible to calculate the difference in electrochemical potential between both solutions. I mean the solutions not the electrodes in the solutions. How should that be done?
Chemistry news on Phys.org
The solutions and salt bridge are 'conductors', except + and - ions carry charge.
In general "The electric field inside the conductor is zero. (Any net electric field in the conductor would cause charge to move since it is abundant and mobile. This violates the condition of equilibrium: net force = 0.)" http://hyperphysics.phy-astr.gsu.edu/hbase/electric/gausur.html#c2
See the discussion here:
https://chem.libretexts.org/Courses...ELECTRO-CHEMISTRY/17.1:_Electrochemical_Cells
Galvanic cells can have arrangements other than the examples we have seen so far (with a salt bridge). For example, the voltage produced by a redox reaction can be measured more accurately using two electrodes immersed in a single beaker containing an electrolyte that completes the circuit. This arrangement reduces errors caused by resistance to the flow of charge at a boundary, called the junction potential.
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
