Satelite and heat from sun and earth.
In summary: Earth between it and the sun is approximately 252.5 K.For part c), the satellite is far away from any stars or planets, so it will not receive any incoming radiation. In this case, the equilibrium temperature will be equal to the background temperature of the universe, which is approximately 2.7 K. This is because the satellite will only be emitting thermal radiation and not receiving any incoming radiation.In summary, the equilibrium temperature of the satellite can be calculated using the Stefan-Boltzmann law and the values for incoming radiation from the sun and Earth. For part a), the temperature is approximately 354.8 K, for part b) it is 252.5 K, and for part c) it
prehisto
115
Assume that a satellite can be modeled as a thermally leading sphere with radius 0.5m and its energy consumption is 200W, and its surface can be described with α=0.3 and ε=0.9.
Determine the equilibrium temperature of satellite in these cases:
a) Satellite is between Earth and sun;
b) Earth is between satellite and sun;
c) Satellite is far away from stars or planets.
Assume that Suns radiation is 1367 Watt/m^2, from Earth reflected 410 Watt/m^2 and that Earth's thermal radiation can be modeled as black body radiation with temperature T=255 K
I know this law R_T=δ*b(T^4-T_∞^4) and the equilibrium state is when radiation=R_T,but that's only the case when one side of the body is isolated. But here i have radiation coming from 2 directions. So can someone please help me, with some ideas ?
First, we need to calculate the total incoming radiation on the satellite from both the sun and the Earth. For part a), the satellite is between the Earth and the sun, so it will receive radiation from both sources. The total incoming radiation can be calculated as follows:
R_in = R_sun + R_earth
Where R_sun is the radiation from the sun and R_earth is the radiation reflected by the Earth. We can use the given values to calculate R_sun and R_earth:
R_sun = 1367 Watt/m^2
R_earth = 410 Watt/m^2
Therefore, R_in = 1367 + 410 = 1777 Watt/m^2.
Now, we can use the Stefan-Boltzmann law to calculate the equilibrium temperature of the satellite. The law states that the rate of thermal radiation (R_T) from a black body is equal to the emissivity (ε) times the Stefan-Boltzmann constant (σ) times the temperature raised to the fourth power (T^4):
R_T = ε * σ * T^4
R_T can also be expressed as the difference between the incoming radiation and the outgoing radiation (R_in - R_out). In this case, the outgoing radiation is equal to the thermal radiation emitted by the satellite:
R_out = ε * σ * T_sat^4
Setting these two equations equal to each other and solving for T_sat gives us:
T_sat = (R_in / (ε * σ))^(1/4)
Substituting in the given values:
T_sat = (1777 / (0.9 * 5.67 * 10^-8))^(1/4) = 354.8 K
Therefore, the equilibrium temperature of the satellite between the Earth and the sun is approximately 354.8 K.
For part b), the satellite is on the opposite side of the Earth from the sun, so it will only receive radiation from the Earth. The total incoming radiation can be calculated as follows:
R_in = R_earth = 410 Watt/m^2
Using the same equation as above, we can calculate the equilibrium temperature of the satellite:
T_sat = (R_in / (ε * σ))^(1/4) = (410 / (0.9 * 5.67 * 10^-8))^(1/4) = 252.5 K
Related to Satelite and heat from sun and earth.
1. How do satellites measure heat from the sun and earth?
Satellites use special instruments called radiometers to measure the amount of heat radiation emitted by the sun and the Earth's surface. These instruments can detect different wavelengths of radiation, including infrared radiation which is emitted by objects that are warm.
2. How does heat from the sun and earth affect satellite operations?
The heat from the sun can affect the functioning of a satellite by causing thermal stress, which can lead to malfunctions or even failure. The heat from the Earth's surface can also interfere with satellite operations, especially for satellites that are closer to the Earth's surface.
3. Can satellites capture images of heat from the sun and earth?
Yes, satellites equipped with thermal infrared sensors can capture images of heat from the sun and earth. These sensors can detect the temperature of objects on the Earth's surface and the amount of heat radiation emitted by the sun.
4. How does the Earth's atmosphere impact the measurement of heat from the sun and earth by satellites?
The Earth's atmosphere can absorb and reflect some of the heat radiation emitted by the sun and Earth's surface, which can affect the accuracy of measurements taken by satellites. However, scientists can account for these atmospheric effects and calibrate the data to obtain accurate measurements.
5. What is the role of satellites in studying the Earth's heat budget?
Satellites play a crucial role in studying the Earth's heat budget, which is the balance between the amount of heat absorbed and emitted by the Earth's atmosphere and surface. Satellites can provide continuous and global measurements of heat radiation, which helps scientists understand and monitor changes in the Earth's heat budget over time.
  • Thermodynamics
