Satellite Orbiting: Speed, Period, Altitude Calc.
  • Thread starter Thread starter squeak
    Satellite
The discussion focuses on calculating the speed, period, and altitude of a 240 kg satellite in a circular orbit 610 km above Earth, considering energy loss during its revolutions. The initial energy is represented as U = GMm/r + h, but confusion arises regarding the factor of one-half in the total energy equation, which includes both kinetic and potential energy. The specific mechanical energy formula is provided, emphasizing the relationship between velocity and orbital radius. Participants clarify that the total mechanical energy is derived from the sum of kinetic and potential energies. The conversation concludes with an understanding of the energy calculations necessary for determining the satellite's parameters.
squeak
Compute the speed and the period of a 240 kg satellite in an approximately circular orbit 610 km above the surface of Earth. The radius and mass of Earth are RE = 6400 km and ME = 6.0 × 1024 kg respectively. [5 marks]
Suppose the satellite loses mechanical energy at the average rate of 1.7 × 105 J per orbital revolution. Adopting the reasonable approximation that the satellite’s orbit becomes a circle of slowly diminishing radius, determine the satellites altitude, speed and period at the end of its 1500th revolution. What is the magnitude of the average retarding force on the satellite? [8 marks]
U = -GMm/r
I'm happy with how to do the first part of the question.
However the second part I'm struggling with.
I have ΔE = 1.7 x 105 x 1500
I then think that the energy of the satellite initially = U = GMm/r+h where h is distance from Earth surface
energy final = GMm/r + hf. This is where I have a problem as the worked solution I have been given states that Einitial = -½ GMm/r+h.
Can anyone explain why its multiplied by half?
The total energy comprises both the kinetic and potential energy of the object in orbit.
Suppose you let ##\mu = G M##, and let R be radius of the orbit. m is the mass of the orbiting object. Then the total specific mechanical energy is:
##ξ = \frac{v^2}{2} - \frac{μ}{r}##
Note: Multiply the specific mechanical energy by the mass m of the body to get the total mechanical energy in joules.
But the velocity of a body in circular orbit is given by ##v = \sqrt{\frac{μ}{R}}##. Make the substitution for v in the specific mechanical energy formula.
Thank you so much. That all makes sense now.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
