Saving a Town from Lava Thermodynamics Problem
  • Thread starter Thread starter BrainMan
    Thermodynamics
The discussion focuses on calculating the mass and rate of water needed to cool lava from 1200 to 800 degrees Celsius and then freeze it. Participants clarify that the mass of lava arriving every minute is 350,000 kg, which informs the required mass of water. There is a consensus that the water will evaporate upon reaching 100 degrees Celsius, and the energy needed for this phase change must be accounted for in the calculations. The correct approach involves adding the latent heat of vaporization to the energy calculations, as the steam produced will not contribute further to cooling the lava. The conversation emphasizes the importance of understanding thermodynamic principles in solving the problem effectively.
BrainMan
Q1 + Q2 = 0
I found the mass of water needed to cool the lava to a solid. I'm not sure how to find the rate of water needed to stop the lava.
https://lh3.googleusercontent.com/HTrvgt1wh2amrK8pZkIgNXe3HUaQ8lUPQHugcY-7NzMPqAZ1jAiB8ws4V4G_E60yfYe03KX23qTVAmIDJuXK7UYo3d685xqE5b0VxHk81jFFbijZbFhwrAP5OcGJV3EDHVH3F72QSP9x1rnut92wI3J-wRRGdXAG43ONxSehJns78s8QTpbIDqU0PT2dLxdQmvd4S6fxPRe4bqtLQG3g34A3aULY6daVs_c7wIFw0N7yQ3pQy1vt9ib6c0CN-rN54HAE8Vdv_yPFA0VMhPx219qiJkE1U5feFCZLKLH16J_ZW4ELwQ5q7eeJnFaZ1mJJsFFv2lmeZU94-WWUiUqUolKMTe1su0a6ejG-ElQLnHBAmzP7-O9briknyffQYrUoeW3T9OANjI21Sa2E73_PUByRrFxrdsHns4L0MARbTys-nXTVReSk1W_RTiFNvWK6mbPk5ChLxZ0uvjq-spgOINTkjj5y615fPGDQ0DKBnWwwssw8mSuso_BGrItJFAWEYhLwmIqIEy42yInjUPnUreOMqJ3hZjDSqhY2Dp654zeCbyUmKr4biZN7g9FFZv0SVxNLgowMuID6t1A1QiqgCwbfk0Rlf7639-l8D3DrAb5AK6UqaYII=w497-h662-no
What happens to the water when it reaches 100 deg C?
The mass of lava you calculated (350000 kg) was the mass of lava that arrives every minute. So the mass of water needed every minute would have to cool that lava down from 1200 to 800 deg C and then freeze it. So it looks like that is what your mass of water is attempting to represent. But like I mentioned at the beginning, water doesn't increase in temp. from 20 to 800 deg C.
Edit: By the way, it looks like your 1.4 e11 and 1.54 e11 numbers are correct.
Likes BrainMan
OK I see. So I need to add MwLv because the water is going to evaporate. Then I need to add nCΔT for water in the gas state until it reaches 800 deg C, right? But what should I use for C for water in the gas phase?
That's the part I was wondering about. I was thinking that once the water turns to steam, it doesn't hang around to be heated up by the lava; it just rises upward never to be heard from again. At least that's what I think would happen.
Likes CWatters and BrainMan
OK you're right. You get the right answer if you just add MwLv. So basically, the Lava is heating up the water to boiling point and then the rest of the energy is removed when the water evaporates to a gas. The steam then "just rises upward never to be heard from again." Thanks!
Likes CWatters and TomHart
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
