Sc-Cr Metal complexes open benzene ring
  • Thread starter Thread starter Astronuc
Benzene's aromaticity presents significant challenges for conversion into linear products under mild conditions. Recent research led by Jiaxiang Chu highlights a novel method using a scandium complex with a pincer-like ligand to interact with benzene. This approach builds on previous work, such as a 2019 aluminum complex that facilitated benzene ring opening. The new study involves mixing the scandium complex with potassium graphite and benzene at room temperature, resulting in an inverted sandwich complex where benzene binds to the scandium complex, allowing it to carry extra electrons in its antibonding orbitals. Scandium's unique properties, including its small size and high charge, enable reactions that other metals cannot achieve, making it a valuable element in this context. The discussion also raises questions about the potential for scandium-chromium complexes to degrade polyaromatic compounds, suggesting further exploration in this area.
Astronuc
Staff Emeritus
https://cen.acs.org/physical-chemis...3/web/2025/07?sc=250723_sc_eng_fb_cen_boosted
Benzene’s aromaticity makes it a tough nut to crack, and there are very few ways to convert it into linear products under mild conditions, says Jiaxiang Chu of the University of Chinese Academy of Sciences, who led the experimental aspects of the work.
Back in 2019, for example, a team led by Simon Aldridge at the University of Oxford made an aluminum complex that inserts itself into benzene, priming it for a reaction with a tin reagent that breaks open the ring. In addition, certain enzymes can pry open the benzene ring in catechol.
The team behind the new study instead drew inspiration from the kinds of metal complexes that can break the strong bonds in dinitrogen or carbon monoxide. First they made a scandium complex containing a pincer-like ligand that stabilizes a range of metal oxidation states. Then they mixed the complex with potassium graphite (KC8), which is a strong reducing agent, and benzene at room temperature. This formed an inverted sandwich complex in which each of benzene’s faces binds to a scandium complex. In this arrangement, the benzene carries four extra electrons in its antibonding orbitals.
“Scandium is always good for a surprise because it’s one of the smallest, highest-charged metal cations,” says Sjoerd Harder of Friedrich Alexander University Erlangen-Nuremberg, an organometallic chemist who uses main-group metal complexes to activate strong bonds. Harder was not involved in the new work. “It can do stuff that other metals can’t do.”
Chemistry news on Phys.org
It is always interesting to see Scandium getting applied.
We inorganic chemists sometimes forget that the first row doesn't start at titanium!
Sc and Y are interesting elements.
Sc is a useful strengthener in Al. Sc is also very expensive given that is produced in few mines.
https://en.wikipedia.org/wiki/Scandium#Applications
https://pubsapp.acs.org/cen/80th/print/scandium.html
https://periodic-table.rsc.org/element/21/scandium
https://www.aemree.com/news/interesting-facts-about-scandium.html
I wonder if it Sc-Cr oomplexes could degrade/decompose polyaromatic compounds, e.g., PCBs, biphenyls, triphenyls, etc.
I havent perused the article, but their illustrations suggest that the benzene ring coordinates axially to the Sc/Sc active site. I am not sure how well polyaromatics can emulate this.
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
