A Scattering cross section between charged particle and magnetic moment
  • A
  • Thread starter Thread starter dark_matter_is_neat
    Scattering amplitudes
dark_matter_is_neat
TL;DR Summary
I'm trying to calculate the scattering cross section between a charged particle and a particle with a magnetic moment using quantum mechanics. I believe the interaction term in this case would be ##\mu \cdot (\vec{v} \times \frac{e\vec{r}}{4 \pi r^{3}})##
I'm trying to calculate the scattering cross section between a charged particle and a particle with a magnetic moment. I believe the interaction term in this case would be ##\mu \cdot (\vec{v} \times \frac{e\vec{r}}{4 \pi r^{3}})## although I'm a bit confused how to properly treat it in this calculation. Would ##\vec{v}## and ##\vec{r}## refer to the relative velocity and position between the two particles, and wouldn't I need to treat ##\vec{v}## as an operator because in principle ##\vec{v} = \vec{p}/m##? If I need to treat the velocity as an operator would I treat ##\vec{p}## as acting on just the wavefunction or should I treat it as acting on the wavefunction and the r terms in the interaction term. In this case the particles are both treated as plane waves so what I'm interested in calculating ##\int d^{3}r_{1}d^{3}r_{2}e^{-i \vec{p'_{1}} \cdot \vec{r_{1}}}e^{-i \vec{p'_{2}} \cdot \vec{r_{2}}}H_{int}e^{i \vec{p_{1}} \cdot \vec{r_{1}}}e^{i \vec{p_{2}} \cdot \vec{r_{2}}}##.
dark_matter_is_neat said:
TL;DR Summary: I'm trying to calculate the scattering cross section between a charged particle and a particle with a magnetic moment using quantum mechanics. I believe the interaction term in this case would be ##\mu \cdot (\vec{v} \times \frac{e\vec{r}}{4 \pi r^{3}})##
What responses are you looking for that weren't covered in your previous thread:
and the references supplied therein?
Likes weirdoguy and PeroK
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
