Schamatics for rutherfords experiment
  • Thread starter Thread starter timeywhimey
    Experiment
Creating a working replica of Rutherford's experiment can be challenging and costly, with specific materials needed for accurate results. Users are encouraged to explore online resources that provide detailed descriptions and interactive simulations of the experiment. Suggestions include using different types of foil, such as lead, tin, and steel, to observe variations in scattering behavior. The discussion highlights the importance of understanding the experiment's fundamentals before attempting a physical model. Engaging with educational simulations may offer a practical alternative to building a physical replica.
timeywhimey
i am really wanting to make a working replica of Rutherford's experiment. but i don't know what kind of material i will need. i also need a schamatic for one
this is my timey whimey detector it goes ding when there's stuff
Could you be more specific?
timeywhimey said:
i am really wanting to make a working replica of Rutherford's experiment. but i don't know what kind of material i will need. i also need a schamatic for one this is my timey whimey detector it goes ding when there's stuff
timewhimey,
I suggest that you consider the difficulty and the expense of making a "working replica" of Rutherford's Experiment. It would be very difficult and very expensive. Here are two sites that describe the the Rutherford Experiment:
http://www.physics.rutgers.edu/meis/Rutherford.htm
http://library.thinkquest.org/19662/low/eng/exp-rutherford.html
Here is an opportunity for one to control an interactive simulation of the Rutherford Experiment provided by the University of Colorado at Boulder:
http://phet.colorado.edu/en/simulation/rutherford-scattering
Cheers,
Bobbywhy
edit: it's spelled "schematic"
i don't know why i said replica what i ment to say is i want to atempt at mimicing experiment myself as well as try other kinds of foil (led, tin, steel) to see which ones goe straight through (or reflect) more than others
I am following someone on Youtube who has built a rocket shaped (4 proprllers) drone for the world speed record ... He was having problems with internal heat from electical control gear and battery inside the sealed rocket (about 1kw waste heat) Speed is 500km/hr , I suggested a 4mm hole in the tip of the nose and 8mm hole at rear which should alow sufficient air cooling .. I said this will increase thrust because the air exiting is hotter .. a bit similar to a ram jet ... was I correct...
