Science Fair Help: Deaf Tap Dancing Invention with Vibration Sensor and Light
An 8th grader is developing an invention for a science fair project aimed at helping deaf individuals enjoy tap dancing by using a wooden board with a vibration sensor that activates a light. The proposed circuit involves connecting a piezoelectric sensor to an LED, which lights up when vibrations are detected. Components can be sourced from local electronics stores or online, and basic circuitry knowledge is recommended for assembly. Resources like YouTube tutorials and articles on inclusive activities can provide valuable guidance and bibliographical information. This innovative project emphasizes accessibility in the arts for individuals with disabilities.
dancemadz
Science Fair Help!
I am an 8th grader at Viewpoint School in California. For my project, I am doing an invention that will enable deaf people to enjoy tap dancing. I plan to make a wooden board with a vibration sensor attached underneath it that the performer would tap on. This sensor would then be attached to a light in a way that it would light up every time the sensor detected a vibration from the board. How would I make this circuit? What kind of light would I need? sensors?
Please either post back, email me(dancingqueen2490@aol.com), or refer me to someone or something else that would have this information. If you post back, I would like bibliographical information for my research as well. Thank you!
Maddie
HELLO OUT THERE?
NOBODY IS POSTING!AAAAAAAAAAAAAAAAH!I AM GETTING FRUSTRATED!IS IT JUST TOO COMPLICATED TO DO?!
(angry maddie)
Hi Maddie,
First of all, I am impressed by your innovative and inclusive idea for your science fair project. It is great that you are thinking about ways to make activities like tap dancing accessible to everyone.
To make the circuit for your invention, you will need a few components such as a vibration sensor, a light, and a power source. You can easily find these components at your local electronic store or online. For the vibration sensor, you can use a piezoelectric sensor that can detect vibrations and convert them into electrical signals. For the light, you can use an LED (light-emitting diode) as it is energy efficient and can be easily controlled by the sensor.
To make the circuit, you will need to connect the vibration sensor to the positive terminal of the LED and the negative terminal to the power source. When the sensor detects vibrations, it will send a signal to the LED, causing it to light up.
In terms of specific instructions, I would recommend doing some research on basic circuitry and how to connect different components together. YouTube tutorials or online forums can also be helpful resources for step-by-step instructions.
As for bibliographical information, you can refer to articles or studies on the benefits of inclusive activities for individuals with disabilities, as well as articles on the use of technology to enhance accessibility in various fields.
I hope this helps and good luck with your project!
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
