Screen not illuminating
  • Thread starter Thread starter Martyn Arthur
The user is experiencing an issue with a 16x2 Serial LCD display not illuminating despite previously functioning correctly. They confirmed the wiring connections, including a resistor and power supply, but the screen remains unresponsive. Questions were raised about potential physical damage or incorrect connections that may have led to the malfunction. After some troubleshooting, the user realized they had misconfigured the wiring, leading to the issue. The discussion highlights the importance of double-checking connections in troubleshooting electronic components.
Martyn Arthur
TL;DR Summary
problem checking bacground on this;Compatible with HD44780 1602 16x2 Serial LCD White Character Blue Backlight Display Board 3.3V 5V Compatible with Arduino
Hellol I have pins for this; apologies for subseqquent bold; bold option is not responsive.
Compatible with HD44780 1602 16x2 Serial LCD White Character Blue Backlight Display Board 3.3V 5V , Using Arduino Uno.
15 and 16 connected; 16 to gnd via a 220ohm resistor and 16 to 5v. Mtest meter reads 5v but the screen is not illuminating.
It had previously been functional. Is any other test possible or is i that the module has become faulty?
Thanks
Martyn
PS: mentor adjusted to remove bold text.
It wasn’t bold tagged it was bracketed by [ head ] tags and that’s why it didn't unbold.
Computer science news on Phys.org
Can you link to the display's datasheet?
Did anything happen as part of it starting to not work? Did it get dropped or plugged in wrong or anything else like that? Is it only the backlight that is not working (can you see dim characters without the backlight?)?
i don't know of anything untoward. Originally just the screen functioned with no characters then it just gave up. Am I correct in believing that the wiring previously described is such that the screen should illuminate?
Thanks
Martyn
Ah got the wiring messed up, ok now; apologies for having wasted your time; thanks for your patience!
Martyn
Likes berkeman and Baluncore
This week, I saw a documentary done by the French called Les sacrifiés de l'IA, which was presented by a Canadian show Enquête. If you understand French I recommend it. Very eye-opening. I found a similar documentary in English called The Human Cost of AI: Data workers in the Global South. There is also an interview with Milagros Miceli (appearing in both documentaries) on Youtube: I also found a powerpoint presentation by the economist Uma Rani (appearing in the French documentary), AI...
