Screen Recorder microphone sound not recorded
  • Thread starter Thread starter Ephant
    Windows 10
The IceCream Screen Recorder app on Windows 10 experienced an issue where the microphone recorded only minimal sound (5%) during a specific screen capture, despite functioning correctly in other instances. The recorded file is in .webm format with Vorbis audio codec, but attempts to open it in Audacity were unsuccessful. The user questioned the possibility of recovering or amplifying the sound, noting that the microphone volume may have been set to zero. Suggestions included testing the microphone cable for faults and considering the limitations of recovering sound that was not recorded. A humorous, impractical method for capturing sound post-event was also mentioned, emphasizing the challenge of retrieving lost audio data.
Ephant
My Windows 10 IceCream Screen Recorder app was not able to record via microphone the sound during a particular screen video capture even if the microphone is turned on (but only 5%). In other instances, the microphone sound is available and also in tests afterwards. I was able to record microphone even if it's only 5%. I don't know what occured in that particular recording. I got the following result in Mediainfo. Can I recover the sound? I tried opening the *.webm file in Audacity but it can't recognize it. How do I recover the sound, or amplify it? Can any of the following information give one idea whether it is recorded? Audio
Format : Vorbis
Format settings, Floor : 1
Codec ID : A_VORBIS
Duration : 27mn 21s
Bit rate mode : Variable
Bit rate : 192 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Compression mode : Lossy
Delay relative to video : -3ms
Stream size : 37.6 MiB (56%)
Writing library : libVorbis (Omnipresent) (20120203 (Omnipresent))
Default : Yes
Forced : No
DURATION : 00:27:21.294000000
Writing application : Lavc57.107.100
Computer science news on Phys.org
Perhaps the microphone cable has a problem; as a test, try recording your voice while wiggling the mic cable and connectors..
A Google search turned up some information:
https://www.google.com/search?&q=playback+for+a_vorbis+encoded
Near the top of the results was this:
Since February 2013, Xiph.Org has stated that the use of Vorbis should be deprecated in favor of the Opus codec, which is also a Xiph.Org Foundation project and also free and open-source.
Good Luck!
Tom
Near the top of the results was this:Good Luck!
Tom
It's from a built in mic in the laptop. I think the problem is the volume is zero for the mic.
Is there a way to still recover the sound? There is a saying information can never be lost. So how do you recover a sound that is not recorded in a file at all?
Wellll ... yea.
The process though is rather impractical.
a) Sound - pressure variations of the air
b) Get a working recorder far enough away fast enough that the sound has not yet arrived.
c) Considering that the Earth is surrounded by a vacuum, you are limited somewhere on the Earth
d) Get to the opposite point on the earth (the antipodes), about 12,000 miles away
e) While traveling faster than the sound, you will also have to develop a method to detect and record the darn near non-existent sound you want.
You have 16.66 hours from the time the sound occured.
Oh well, time to cry in your beer. :cry:
This week, I saw a documentary done by the French called Les sacrifiés de l'IA, which was presented by a Canadian show Enquête. If you understand French I recommend it. Very eye-opening. I found a similar documentary in English called The Human Cost of AI: Data workers in the Global South. There is also an interview with Milagros Miceli (appearing in both documentaries) on Youtube: I also found a powerpoint presentation by the economist Uma Rani (appearing in the French documentary), AI...
