Second functional derivative of fermion action
The discussion centers on calculating the second functional derivative of a fermionic action involving Dirac spinors. The main issue arises from the anticommuting nature of Grassmann variables, leading to confusion about the signs in the derivative calculations. Participants highlight the importance of correctly handling delta functions and derivatives, noting that integration by parts is not applicable in this context. A key point is the identity for the derivative of the delta function, which helps clarify the discrepancies in results. Ultimately, consistency in the treatment of variables and derivatives is crucial for arriving at the correct expression for the propagator.
Ravendark
[/B]
Consider the following action:
$$\begin{align}S = \int \mathrm{d}^4 z \; \bar\psi_i(z) \, (\mathrm{i} {\not{\!\partial}} - m)_{ij} \, \psi_j(z)\end{align}$$
where ##\psi_i## is a Dirac spinor with Dirac index ##i## (summation convention for repeated indices). Now I would like to calculate the (inverse) propagator ##G_{kl}(x,y)##, i.e., the second functional derivative of the action:
$$\begin{align}G_{kl}(x,y) = \frac{\delta^2 S}{\delta \psi_l(y) \delta \bar\psi_k(x)}\end{align}$$
My actual problem deals with the anticommuting of Grassmann quantities. Since the derivatives are Grassmann, I should find (is this correct at all? It is quote from the lecture notes I'm using)
$$\begin{align}\frac{\delta^2 S}{\delta \psi_l(y) \delta \bar\psi_k(x)} = - \frac{\delta^2 S}{\delta \bar\psi_k(x) \delta \psi_l(y)} \; .\end{align}$$
Unfortunately, my calculation yields something different.
2. Conventions
Integral: ##\displaystyle \int_z \equiv \int \mathrm{d}^4 z##
Functional derivative: ##\; \dfrac{\delta \psi_i(x)}{\delta \psi_j(y)} = \delta_{ij} \, \delta^{(4)}(x-y) = \dfrac{\delta \bar\psi_i(x)}{\delta \bar\psi_j(y)}##
Left hand side:
$$\begin{align}
\frac{\delta^2 S}{\delta \psi_l(y) \delta \bar\psi_k(x)} &= \frac{\delta}{\delta \psi_l(y)} \int_z \, \delta_{ik} \, \delta^{(4)}(z-x) \, (\mathrm{i} {\not{\!\partial}} - m)_{ij} \, \psi_j(z) \\ &= \frac{\delta}{\delta \psi_l(y)} \, (\mathrm{i} {\not{\!\partial}} - m)_{kj} \, \psi_j(x) \\ &= (\mathrm{i} {\not{\!\partial}} - m)_{kj} \, \delta_{jl} \, \delta^{(4)}(x-y) \\ &= (\mathrm{i} {\not{\!\partial}} - m)_{kl} \, \delta^{(4)}(x-y)
\end{align}$$
Looks good so far (?), now the next part...
Right hand side:
$$\begin{align}
- \frac{\delta^2 S}{\delta \bar\psi_k(x) \delta \psi_l(y)} &= \frac{\delta}{\delta \bar\psi_k(x)} \int_z \, \bar\psi_i(z) \, (\mathrm{i} {\not{\!\partial}} - m)_{ij} \, \delta_{jl} \, \delta^{(4)}(z-y) \\ &= \frac{\delta}{\delta \bar\psi_k(x)} \int_z \, \bar\psi_i(z) \, (\mathrm{i} {\not{\!\partial}} - m)_{il} \, \delta^{(4)}(z-y) \\ &= \frac{\delta}{\delta \bar\psi_k(x)} \left\{ \int_z \, \bar\psi_i(z) \, \mathrm{i} \, \gamma^\mu_{il} \, \partial_\mu \, \delta^{(4)}(z-y) - \int_z \, \bar\psi_i(z) \, m_{il} \, \delta^{(4)}(z-y) \right\} \\ &= \frac{\delta}{\delta \bar\psi_k(x)} \left\{ - \int_z \, (\partial_\mu \bar\psi_i(z)) \, \mathrm{i} \, \gamma^\mu_{il} \, \delta^{(4)}(z-y) - \bar\psi_i(y) \, m_{il} \right\} \\ &= \frac{\delta}{\delta \bar\psi_k(x)} \bigl\{ - (\partial_\mu \psi_i(y)) \, \mathrm{i} \, \gamma^\mu_{il} - \bar\psi_i(y) \, m_{il} \bigr\} \\ &= -\delta_{ik} \, \partial_\mu \, \delta^{(4)}(y-x) \, \mathrm{i} \, \gamma^\mu_{il} - \delta_{ik} \, \delta^{(4)}(y-x) \, m_{il} \\ &= (-\mathrm{i} {\not{\!\partial}} - m)_{kl} \, \delta^{(4)}(y-x)
\end{align}$$As you can see, there is an additional minus sign in front of the derivative part...and I have no idea how to "remove" it. Can someone give me a hint please?
EDIT:
I noticed right now that the arguments of the delta functions are still swapped. I can fix the mass part by using that the delta function is even, i.e., ##m_{kl} \, \delta^{(4)}(y-x) = m_{kl} \, \delta^{(4)}(x-y)##. But the derivative part confuses me a bit because I never dealt with a derivative of a delta function in such a way.Best Regards,
Ravendark
You don't use integration by parts to transfer the spacetime derivative onto PsiBar since <br /> \; \dfrac{\delta \psi_i(x)}{\delta \psi_j(y)} = \delta_{ij} \, \delta^{(4)}(x-y) = \dfrac{\delta \bar\psi_i(x)}{\delta \bar\psi_j(y)}<br /> you have the choice over which delta function you integrate first<br /> \frac{\delta}{\delta \bar\psi_k(x)} \int_z \, \bar\psi_i(z) \, (\mathrm{i} {\not{\!\partial}} - m)_{il} \, \delta^{(4)}(z-y)=\int_z \, \delta^{(4)}(z-x) \, (\mathrm{i} {\not{\!\partial}} - m)_{kl} \, \delta^{(4)}(z-y)
So integrating over the left delta function will give you the desired result
Likes Ravendark
Right...instead of transfer the derivative to ##\bar\psi## I can perform the derivative directly since I know how the derivative w.r.t. ##\bar\psi## looks like.
But why is it "forbidden" to use partial integration ((11) to (12) in my first post) at this point (apart from the fact that this yields a wrong result)?
Forgive me what I should have said is you don't have to transfer the space-time derivative. You are free to do so
Likes Ravendark
Thank you very much, I got it...I totally forgot, that there exists an identity for the derivative of the delta function: ##\partial_\mu \delta^{(4)}(y-x)=-\partial_\mu \delta^{(4)}(x-y)##.
I'd be careful here because the RHS gives \frac{\partial}{\partial x^{\mu}}\delta^4(x-y) whilst the LHS gives you \frac{\partial}{\partial y^{\mu}}\delta^4(y-x) if you set t=x-y and use the identity you gave above you can see that \frac{\partial}{\partial x^{\mu}}\delta^4(x-y)=\frac{\partial}{\partial y^{\mu}}\delta^4(y-x) so this wouldn't get rid of your minus sign. The reason why you find these inequalities is because on the RHS you're integrating over a delta function whilst on the LHS you're integrating over the derivative of a delta function. If you are consistent on both sides you get the right answer
Mhh, it seems you're right...
Now I'm a bit confused...about which RHS/LHS are you talking about?
You mean consistent on which argument ##\partial_\mu## actually acts?
