Second order DE from my midtearm
  • Thread starter Thread starter Danny B
    Second order
Danny B
Consider the ODE:
y''+p(x)y'+q(x)y=g(x)
It is given that the functions y=x^{2}, y=x and y\equiv1
are solutions of the equation.
Find the general solution of the equation.
Well, given the three solutions, and taking into account that they are mutually linearly independent, I would say that any couple of these functions will give me a set that forms the general solution.
If i take y=x and y\equiv1, I get the general solution:
y(x)=c1+c2*x
Now, I know that x^{2} is also a solution, but it can't be derived from the general solution, so obviously I'm doing something wrong.
I also thought of the possibility that y=1 is a singular solution and the general solution is:
y(x)=c1*x+c2*x^2
does this makes sense?
This is a question from my midterm and i still can't figure it out. So... help?
Welcome to PF!
Hi Danny B! Welcome to PF! :smile:
(try using the X2 and X2 icons just above the Reply box :wink:)
Each of those three are particular solutions …
Hint: what relation is there between any two particular solutions (ie any two solutions)? :wink:
Thank you.
I think I got it now.
My mistake was to use the principle of superposition with a non-homogeneous equation.
So the general solution should be:
(Considering that any difference of the particular solutions is a homogeneous solution)
y_{(x)}=c_{1}(x-1)+c_{2}(x^{2}-1)+Y_{p}
But how do I choose Y_{p}?
Can I just use any of the three particular solutions?
Hi Danny B! :smile:
Let's write it out in full, so you can see how it works …
the general solution can be written in three ways
A(x2 - 1) + B(x - 1) + 1
A(x2 - x) + x + B(1 - x)
x2 + A(x - x2) + B(1 - x2)​
the homogeneous general solution can be written in three ways
A(x2 - x) + B(1 - x)
now you need to spend ten minutes convincing yourself that they're the same! :rolleyes:
he he :biggrin:
Thanks a lot!
You've been a great help!
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
