Seeking a example of noholonomic constraint
In summary, dot cancellation does not work if the position vector is a function of both the generalized coordinates and velocities, as in the case of certain non-holonomic constraints. This can cause issues when using D'Alembert's principle and arriving at the Euler-Lagrange equations.
xephyrind
I was reading up classical mechanics in Goldstein but needed some clarifications. I looked online and saw something that bothers me qutie a bit. In the online pdf below, on page 69 (or 74th screen scrolls), it states that Dot Cancellation does not work if the position vector is a function of BOTH generalized coordinates AND generalized velocities such that \vec_r = \vec_r(q_1, q_2, ...; \dot_q_1, \dot_q_2, \dot_q_3). On top, the PDF states that it happens for certain non-holonomic constraints. Since this dot cancellation is central to using D'Alembert's principle to arrive at the form of Euler-Lagrange Equations. I am wondering where this Dot Cancellation would fail.
Dot Cancellation: d(\vec_r)/dq = d(\vec_v)/d(\dot_q)
http://www.astro.caltech.edu/~golwala/ph106ab/ph106ab_notes.pdf
Question:
Would someone kindly give me an example such that the position vector \vec_r actually depends on generalized velocities as well as the constraints that causes it please? Thanks much.
Answer: One example is a system with a non-holonomic constraint involving a rolling surface. In this case, the position of the system depends on both the generalized coordinates and velocities. The constraint can be expressed as:\vec_r \cdot \hat_n = 0,where \hat_n is a unit vector normal to the surface. This means that the position of the system can only lie on a certain surface. The velocity of the system must also be perpendicular to the surface, which implies that it is a function of both the generalized coordinates and velocities. As a result, dot cancellation does not work in this case.
Related to Seeking a example of noholonomic constraint
1. What is a noholonomic constraint?
A noholonomic constraint is a type of constraint in a mechanical system that restricts the motion of the system without explicitly imposing any forces or energy. It can be seen as a mathematical relationship between the state variables of the system, which limits the possible configurations and velocities.
2. What is an example of a noholonomic constraint?
A common example of a noholonomic constraint is a car's steering system. The steering wheel can only turn in a certain range, which restricts the motion of the car to only move in a forward or backward direction. This constraint is not explicitly imposed by any forces, but rather by the geometry of the steering mechanism.
3. How is a noholonomic constraint different from a holonomic constraint?
A holonomic constraint is a constraint that can be expressed by a set of equations involving only the position variables of a system. In contrast, a noholonomic constraint involves both position and velocity variables and cannot be expressed by a set of equations. This means that holonomic constraints can be satisfied at any instant, while noholonomic constraints must be satisfied continuously.
4. Can a noholonomic constraint be removed?
In some cases, a noholonomic constraint can be removed by introducing additional degrees of freedom to the system. For example, a car with four-wheel steering has more degrees of freedom than a car with only two-wheel steering, allowing for more complex motion and removing the constraint.
5. How are noholonomic constraints used in robotics?
Noholonomic constraints are commonly used in robotics to restrict the motion of a robot in a desired way. They can help simplify the control of a robot by limiting its possible movements and making it easier to plan and execute tasks. For example, a robot arm with a noholonomic constraint on its joint angles can only move in a certain range, making it easier to manipulate objects in a specific area.
  • Science and Math Textbooks
  • Mechanics
  • Classical Physics
  • Astronomy and Astrophysics
