Seeking a reasonable mathematical explanation to a simple mathematical conundrum
The discussion revolves around the mathematical conundrum of the equality between 0.999... and 1. The original poster expresses confusion over how multiplying and subtracting in their calculations leads to the conclusion that 0.999... equals 1, despite starting with a different value. Participants clarify that 0.999... represents an infinite series, not a value approaching 1, and emphasize that it is not finite. They argue that the misunderstanding arises from viewing 0.999... as a limit rather than an actual value. The conversation highlights the complexities of decimal expansions and the nature of infinite series in mathematics.
cheenusj
Hi everyone,
I came upon a simple mathematical conundrum a few decades ago that has irked me for a while now and for which I don't have a reasonable mathematical explanation.
The only reasonable "explanation" I currently have is that 'certain mysterious things happen when tending towards infinity', whether infinitely big or infinitesimally small, say for example triangle angles summing to more than 180 degrees in infinitely large non-Euclidean triangles.
The problem is just one equation and I am hoping you have either heard of this "problem" or have a reasonable or better explanation than "mysterious things happen towards infinity".
Say, x = 0.9... (tending towards infinite, i.e. I don't have the "bar" to go on top of the "9" for mathematical notation).
Multiply both sides of the equation by 10 and you obtain 10x = 9.9... (tending towards infinity).
Subtract the latter from the former and since the ".9..." tending towards infinity knock themselves out, you have 9x = 9 (10x-x = 9.9...-0.9...), therefore x = 1.
However, "x" started off at x=.9 tending towards infinity, not x = 1.
Since multiplication is a series of additions and substraction being a negative addition, the process of multiplying something out, then doing a substraction and then simplifying it should always leave everything as it first started, without changing anything, i.e. you should end up with what you started with.
Taking a set of 'simpler' examples, this is easily observable and the above example seems "idiotic" (pointless), because the mathematical operators used will always result in ending with the same x-value that one started off with.
I also seem to find a "pedestrian" explanation that seems to illustrate the head-scratcher that this is for me.
One-ninth is 0.1 tending towards infinity, i.e. 1s going on forever.
Two-ninths is 2 times one-ninth, therefore I can easily derive that each "1 digit" behind the decimal point can be multiplied by 2. Therefore, two-ninths is 0.2 tending towards infinity.
I can keep incrementing and this is always correct until eight-ninths which is once again 0.8... (tending towards infinity). But then what is nine-ninths? Obviously it's "one", but if I used the logic above, one could easily argue that each 1-digit after the decimal is multiplied by 9, resulting in 0.9 tending towards infinity, which is wrong.
Since this "issue" has been bugging me for a while and I don't have any other contcts in academia or the field of mathematics, I was wondering what explanation and what "mistake" is held in the logic of the above "equation" and operations?
Many thanks for your thoughts.
Kind regards,
Cheenu
London, U.K.
Mathematics news on Phys.org
9 * 1/9 = 1. If we have 0.999... the number 0.000...1 can be added to 0.999... to obtain 1. What happens to 0.000...1 as the number of places between the 1 and the decimal point increases without bound? One could say that decimal expansions of rational numbers sometimes leave something to be desired. :o
Yes, but isn't that what you were trying to prove? You wouldn't have achieved anything if you ended up with $x= 0. \overline{9} $.
I don't understand this logic. If I start with $x = \cos(0)$ is it wrong to end up with $x=1$?
Or let's say if I start with $x= \sqrt[3]{7+5\sqrt{2}}+ \sqrt[3]{7-5\sqrt{2}}$ is it wrong to end up with $x = 2$?
As long as you follow the rules of whatever field you're working with, you can end up with a different forms of the same thing.
0.999... does not mean "tending towards" anything It means there ARE infinitely many. It NEVER quits. Your entire dilemma stems from your assumption that it is somehow finite. It isn't.
I always find it useful to ask, If 0.9999... is NOT equal to 1, then how far from 1 is it? You cannot answer this question. Anything you pick, another can show how it is not that far.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
