Seeking Guidance on Internal Floating Roof Tank Construction with Dome Roof
The discussion focuses on the construction of an Internal Floating Roof (IFR) tank with a dome roof, emphasizing the need for guidance and resources due to the author's inexperience. Key inquiries include the applicable national code for construction, the type of liquid to be stored, and specific tank dimensions. The project is identified to follow API 650 standards, with dimensions specified as a diameter of 8 meters and a height of 5 meters. The author seeks expert advice to ensure successful project execution. Overall, the conversation highlights the importance of understanding technical requirements in tank design and construction.
dzfr
Dear Engineers,
I hope this message finds you well. I'm reaching out to seek guidance on a new project that I am undertaking: the construction of an Internal Floating Roof (IFR) tank with a dome roof. As I am relatively new to this position, this project presents a significant learning opportunity for me.
Recognizing the complexity and importance of this endeavor, I am eager to gather as much knowledge and insight as possible to ensure its successful execution. Therefore, I would greatly appreciate any resources, documents, or site links that you could share to aid in my understanding of the intricacies involved in the construction and design of such a structure.
Your expertise and assistance in this matter would be invaluable to me as I navigate through this project. Thank you in advance for any support you can provide.
Best regards,
Welcome to PF.
Under which national code will the tank be built?
What liquid will be stored in the tank?
What are the tank dimensions?
Baluncore said:
Welcome to PF.
API 650
Essence
D=8. H=5
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
