some bloke
- 279
- 98
- TL;DR Summary
- I want to make a shaft damper (such as that which connects a motorcycle rear sprocket carrier to the rear wheel) which can be adjusted in stiffness. I am sure that there will be such a design in the world, but I don't know where to start looking, or the right terms!
Hello everyone!
I am brainstorming a project which will require an adjustably damped shaft connector, which is a term I'm making up and I think it's about right.
The shaft will be driven at one end, with an intermittent drive. There will be a shaft dampener after this, which will cushion changes in shaft speed, either by springs or rubber mounts. The other end of the shaft will be fitted to a load which is subject to change during use.
I would like to find a way to change the stiffness of the dampening in the shaft dampener, whilst the mechanism is running, so that it goes anywhere from a hard start/stop to a very soft, cushioned one. I don't have exact requirements for the cushioning, as I will need to approach this by trial and error.
For the dampener, I have considered an air bladder for the cushion, but this would necessitate an air compressor, which I would prefer to avoid if possible. I am contemplating some form of magnetic braking, or a pair of leaf spring arcs which are squeezed together at one end, and the position of the closed part is adjusted by rotating a servo.
I anticipate that a real-time adjustable shaft dampener is likely to be something which exists already, but my google-fu is coming up weak I'm afraid! Does anyone know of any such mechanism?
