Selection rules in electric dipole appoximation
In summary, the selection rule for electric dipole approximation for angular momentum is ##\Delta j = 0, \pm 1## or ##\Delta l = -1, 0, 1##, but only transitions with ##j \geq 1## are allowed due to conservation of angular momentum. This is because the electromagnetic field does not couple to spin, resulting in a change of ##\Delta S = 0## for many-electron atoms.
blue_leaf77
2,637
786
Some literatures say that the selection rule in electric dipole approx. for angular momentum ##\Delta j = 0,-1,1## some other say ##\Delta l = -1,1##. I follow the notation used in my references, despite the difference I think since j and l are both angular momenta which fulfill angular momentum commutation relations, I can regard them to be the same. But why are they different?
##\Delta l = \pm 1## is due to conservation of angular momentum, as a photon has spin 1. But since ##\hat{\jmath} = \hat{l} + \hat{s}##, you can find combinations of ##l## and ##s## (or ##m_l## and ##m_s##) such that ##l## changes by 1, but ##m_l## changes also such that ##j## doesn't change. Note that this is not possible when ##j = 0##, such that ##j = 0 \rightarrow j'=0## transitions are forbidden (i.e., only for ##j \geq 1## is ##\Delta j = 0## allowed).
DrClaude said:
but ##m_l## changes
Did you mean ##s## in place of ##m_l##?
No. The electromagnetic field doesn't couple to spin, so you have ##\Delta S = 0## for many-electron atoms.
If I take an example of transition from ##1s_{1/2}## to ##2p_{1/2}##, would that be a good example?
Starting from ##l=0, m_l = 0, s= 1/2, m_s = 1/2, j= 1/2, m_j = 1/2##, the atom can absorb a ##\sigma^-## photon (##\Delta l = 1##, ##\Delta m_l = -1##), to end up in the state with ##l=1, m_l = -1, s= 1/2, m_s = 1/2, j= 1/2, m_j = -1/2##.
Note that the same photon can also lead to a transition to ##l=1, m_l = -1, s= 1/2, m_s = 1/2, j= 3/2, m_j = -1/2##.
Likes DrDu and blue_leaf77
Related to Selection rules in electric dipole appoximation
What is the electric dipole approximation?
The electric dipole approximation is a commonly used approximation in quantum mechanics that simplifies the calculation of the interaction between an electromagnetic field and an atom or molecule. It assumes that the size of the atom or molecule is small compared to the wavelength of the electromagnetic radiation, and that the electric field produced by the radiation is approximately constant over the size of the atom or molecule.
What are selection rules in electric dipole approximation?
Selection rules in electric dipole approximation are rules that govern which transitions between energy levels in an atom or molecule are allowed or forbidden. These rules are based on the conservation of energy, momentum, and angular momentum, and they determine which transitions can occur through the absorption or emission of electromagnetic radiation.
How are selection rules determined in electric dipole approximation?
Selection rules are determined by considering the change in the quantum numbers of the atom or molecule during a transition, as well as the properties of the electromagnetic radiation. For example, in the electric dipole approximation, transitions are only allowed if the change in the quantum number of the electronic state is ±1, and the polarization of the radiation must match the symmetry of the electronic wavefunction.
What is the significance of selection rules in electric dipole approximation?
Selection rules in electric dipole approximation are important because they determine which transitions are allowed or forbidden, and thus which spectral lines are observed in the absorption or emission spectrum of an atom or molecule. They also provide important insights into the structure and properties of atoms and molecules, and can be used to study the interaction between matter and electromagnetic radiation.
Are selection rules in electric dipole approximation always strictly followed?
No, selection rules in electric dipole approximation are not always strictly followed. There are exceptions, such as in special cases of symmetry or in the presence of external perturbations. However, in most cases, selection rules are highly accurate and can be used to predict and interpret experimental results in quantum mechanics.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Atomic and Condensed Matter
  • Quantum Physics
12K
  • Quantum Physics
