Semantics question about this angular momentum problem
The discussion revolves around calculating the angular momentum of an airplane relative to a wheat farmer on the ground. The initial calculation yields an angular momentum of -9.03 x 10^9 kg x m^2/s, which is correct. The key point is that while the distance between the farmer and the plane increases, the effective distance used in the angular momentum formula, r*sin(Θ), remains constant due to the altitude of the plane. Thus, even as the plane moves west, the angular momentum remains unchanged because the angle θ adjusts accordingly. The confusion arises from interpreting the relationship between the plane's motion and the farmer's position, but the physics confirms that angular momentum is constant in this scenario.
FisherDude
Heading straight toward the summit of Pikes Peak, an airplane of mass 12,000 kg flies over the plains of Kansas at nearly constant altitude 4.30 km with constant velocity 175 m/s west. a) What is the airplane's vector angular momentum relative to a wheat farmer on the ground directly below the airplane? b) Does this value change as the airplane continues its motion along a straight line?
mag. of angular momentum = position*mass*velocity*angle between
The answer to part a) is (-9.03 x 10^9 kg x m^2/s) j, which I have no problem with. But the answer to part b) is "No, L = |r||p|sin(Θ) = mv(rsinΘ), and r*sinΘ is the altitude of the plane. Therefore, L = constant as the plane moves in level flight with constant velocity."
But the problem asks for the plane's angular momentum relative to the wheat farmer. So if the plane keeps on moving west, wouldn't r (the distance between the farmer and the plane) keep on increasing?
The only way the answer makes sense to me is if they're really asking for the angular momentum of the plane relative to the ground, not the wheat farmer, because then, the distance between the plane and the ground would be constant.
Any help would be great...
Sure, the distance r from farmer to plane increases. But r*sinΘ does not. Angular momentum is not just mv*r, but mvr*sinΘ. (Only when the plane is directly overhead does sinΘ = 1.)
Note that r*sinΘ is the distance between plane and ground.
You're correct, L remains constant even with the farmer. You realized that r*sin(theta) is simply the altitute, which is constant. You're correct that r will increase because the plane-farmer distance increases. However, sin(theta) will decrease at such a rate to keep L constant. Remember what the angle theta is defined as. It's the angle between the vector r and the vector v. You were allowed to ignore this in your origional calculation because theta = 90 Sin(theta) = 1
Wow, I wish i had caught that.
Thanks!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
