Semiconductor physics: Resistivity,mobility and concentration.
The discussion focuses on calculating intrinsic hole and electron concentrations in pure silicon at 300 Kelvin, given its resistivity and mobility ratios. The resistivity is noted as 950Ωm, with an electron mobility of 0.12 m²/V·s and a hole mobility derived as 0.04 m²/V·s based on the provided mobility ratio. The conductivity equation is applied, leading to the formulation of a relationship between carrier concentrations and mobilities. The resulting calculations yield both electron and hole concentrations at approximately 4.118 x 10^16 m^-3. Emphasis is placed on the importance of including units in final answers to avoid losing points.
Aerozeppelin
If a sample of pure silicon at 300 Kelvin has a resistivity of 950Ωm, and if the electron-to-hole mobility ration is 3:1, with the electron mobility equal to 0.12m2V-1s-1, what are the intrinsic hole and electron concentrations?
I know resistivity is equal to
\frac{ρL}{A}. But I don't think this is applicable. I cannot find any equations in books or on the internet connecting these properties (concentration, mobility and resistivity).
Well considering the ratio of electron to hole mobility is 3:1, I presume that the hole mobility is 0.04m2V-1s-1 (ie. electron mobility divided by 3). After that, I'm completely lost!
Any help would be appriciated! :smile:
You should be able to write the conductivity of the silicon (inverse of the resistivity) in terms of the concentration of carriers and their mobility. If you haven't learned this, Google it.
Can't believe I didn't think of that!
Thanks a million.
Here's my answer if anyone wants it.
σ=\frac{1}{ρ}
1.053x10-3 = q (nμn + pμp)
Where:
q is the charge of an electron.
μn is the mobility of electron. = 0.12
And μp is the mobility of holes. = 0.04
To solve for concentrations (n and p),
Rearranging,
0.12n + 0.04p = 6.579x1015
N = P in intrinsic.
∴ 0.16n = 6.579x1015
& p = n = 4.118x1016
Looks good, I think you did it all correctly. However, there are no units on the answer. I always take off points for a number with no units.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
