Sensor "pixels" count vs digital image output pixels count
In summary, the count of sensor "pixels" refers to the number of individual light-sensitive elements on a camera sensor, while digital image output pixels count indicates the final resolution of the image produced. The sensor's pixel count influences the amount of detail captured, but the output pixel count can be altered through image processing techniques such as resizing or interpolation. Therefore, a high sensor pixel count doesn't always guarantee a high-quality image output, as factors like lens quality and sensor technology also play significant roles.
fog37
1,569
108
TL;DR Summary
sensels vs pixels
Hello,
  • I did some reading and wanted to check with you to make sure I have the correct information: in general, a digital camera is rated with so many Mega pixels which indicate the number of pixels of the largest image (mm x mm) that the camera can produce. The camera sensor (CCD or CMOS) has "pixels" too which are more properly called sensels. The number of sensels and the number of pixels of the digital image are generally not the same. "In general", the number of sensels is larger, correct?
  • The larger the camera sensor, the larger the light collecting area, the larger the sensels will be. The camera resolution is determined by the sensel's size and the magnification (which depends on the lens).
  • In general, and surprisingly for me, a larger sensor with larger sensels is a technically better choice but the price is higher. I tend to think that the more sensels the better because that would increase image resolution...
Thank you!
Is it? I thought the number of photosites (sensels I guess, which is the first time I've ever heard of this term) was generally equal to the pixels in the resulting image.
No, the physical size of the sensor and the physical size of the sensels are not necessarily related. One can have a very small sensor with very small sensels (for a large density) or a very large sensor with very large sensels (for a low density), or anything in between.
It depends. Two sensors of identical physical size but with different size sensels will have different resolutions. But a larger sensor can have more sensels yet have the same resolution if the sensels are the same physical size as a smaller sensor.
If each pixel has three "sensels", one for each colour, does that explain it?
Likes phinds
My understanding was that each pixel corresponded to one sensel, even in color sensors. There is just some processing going on to get the color data from the surrounding sensels.
Likes russ_watters
The word "sensel" is pedantically correct (it is a contraction of "sensor element") but does not refer to anything different than a "pixel", which because it is a contraction of "picture element" should strictly speaking only refer to displays, not sensors.
Likes phinds
Re light gathering and image quality.
Imagine two cameras, each giving a 24 Megapixel image. One camera has a large sensor, say 1inch by 1.5inch, and the other has a sensor 1cm by 1.5cm. Each has the same number of sensels to give the resulting 24megapixel image. So the sensels on the 1cm by 1.5cm sensor must be much smaller than on the 1inch by 1.5inch sensor.
So the larger sensor can gather more light at any given exposure, the signals from the sensels need less amplification to be processed and the result is a better quality image. Because the amplification require in the camera with smaller sensels can introduce more random noise. And thus its harder for it to give a good image (lots of signal amplification required) in low light conditions.
That's my understanding of it anyway.
That assumes they employ the same optics, but the optical magnification used would be different.
The available light energy is a function of the objective lens area or aperture, spread over the same number of sensels.
Likes fog37
Assuming the same optical setup, yes. The smaller sensor will also have better 'resolution' in the sense that it resolves finer details if the optical system allows. The larger sensor has less resolution but a much larger field of view.
Likes sophiecentaur and fog37
The f number of the lens is relevant too. A wide aperture lens will admit more light (obvs) but its focal length will govern the illumination of a sensor element.
FAQ: Sensor "pixels" count vs digital image output pixels count
What is the difference between sensor pixels and digital image output pixels?
Sensor pixels, also known as photosites, are the individual light-sensitive elements on a camera sensor that capture light and convert it into electrical signals. Digital image output pixels are the pixels in the final image file that you see on your screen or print. While sensor pixels capture the raw data, digital image output pixels are the processed result of that data after going through various algorithms and adjustments.
Why do some cameras have more sensor pixels than the output image resolution?
Some cameras use a technique called pixel binning, where multiple sensor pixels are combined to form a single output pixel. This can improve image quality by reducing noise and increasing dynamic range, especially in low-light conditions. Additionally, cameras may oversample the sensor data and then downscale it to produce a higher-quality final image with better detail and color accuracy.
How does sensor pixel count affect image quality?
A higher sensor pixel count can potentially provide greater detail and resolution in an image, allowing for larger prints and more flexibility in cropping. However, other factors like sensor size, pixel size, and the quality of the camera's image processing algorithms also play significant roles in determining overall image quality. More pixels can sometimes lead to increased noise, especially in smaller sensors.
Can the number of sensor pixels be higher than the number of output pixels in the final image?
Yes, the number of sensor pixels can be higher than the number of output pixels. This is often the case in cameras that use pixel binning or other image processing techniques to enhance image quality. The camera captures more data than needed and then processes it to create a final image with fewer, but higher-quality, output pixels.
Is a higher sensor pixel count always better for photography?
Not necessarily. While a higher sensor pixel count can provide more detail, it also means smaller individual pixels, which can be more susceptible to noise, especially in low light. The overall performance of a camera depends on a balance of factors including sensor size, pixel size, lens quality, and image processing capabilities. In some situations, a camera with fewer but larger pixels might produce better results than one with a higher pixel count.
13K
