Separation of Variables: Solving M(dv/dt) = [k*(v^2)] - Mg
In summary, to solve the separation of variables problem of M(dv/dt) = [k*(v^2)] - Mg, you can use partial fractions or a trig substitution to integrate dv/(kv2 - Mg). Then, a substitution of v=\sqrt{\frac{Mg}{k}} \cosh p in the LHS can help solve the integral.
Richard Platt
Help solving this separation of variables. M(dv/dt) = [k*(v^2)] - Mg
As above
dv/(kv^2-Mg)= dt/M
Intregrate both sides;
(1/2kv) ln |kv^2-Mg|= t/m + c?
Then what to do..? Something to do with with Ae^(-kt/M)..?
As above
dv/(kv^2-Mg)= dt/M
Your integration is wrong here. You apparently thought you were working with [itex]\int du/u[/itex], but you weren't. If u = kv2 - Mg, then du = 2kvdv, but you can't just stick in a factor of v as you seem to have done.
To integrate dv/(kv2 - Mg), break the denominator up using partial fractions. Alternatively, you could use a trig substitution, but partial fractions would probably be easier.
P.S. Welcome to PF!
In the LHS a substitution [itex] v=\sqrt{\frac{Mg}{k}} \cosh p [/itex] would help you solve the integral, assuming [itex] k,m,g > 0 [/itex].
Related to Separation of Variables: Solving M(dv/dt) = [k*(v^2)] - Mg
What is separation of variables?
Separation of variables is a method used in mathematics and physics to solve partial differential equations. It involves separating a multi-variable function into simpler single-variable functions to make solving the equation easier.
Why is separation of variables important?
Separation of variables is important because it provides a systematic and efficient way of solving complex partial differential equations. It is also used to model and understand various physical phenomena, such as heat transfer, wave propagation, and quantum mechanics.
What types of equations can be solved using separation of variables?
Separation of variables can be applied to linear partial differential equations, such as the heat equation, wave equation, and Laplace's equation. It is also used in solving certain types of nonlinear equations, such as the nonlinear Schrödinger equation.
What are the steps involved in separation of variables?
The steps involved in separation of variables are:
  • Express the given equation in terms of partial derivatives.
  • Assume a solution in the form of a product of single-variable functions.
  • Substitute the assumed solution into the equation and separate the variables.
  • Solve each resulting equation for the single-variable functions.
  • Combine the solutions to obtain the general solution of the original equation.
Are there any limitations to using separation of variables?
Yes, there are limitations to using separation of variables. It can only be applied to linear partial differential equations with homogeneous boundary conditions. Nonlinear equations and equations with non-homogeneous boundary conditions require different methods to solve. Additionally, not all equations can be solved using separation of variables, and sometimes the method may not yield a complete solution.
