Series RLC - calculate V w/ different ƒ
  • Thread starter Thread starter dwn
    Rlc Series
To calculate the voltage across the resistor in a Series RLC Band Pass Filter, the relevant equations include w = 2pi*ƒ and V = R*Vi / (jwL + 1/jwC + R). The user seeks to determine this voltage for various frequencies using a source voltage of 5 Vpp, a resistance of 2700Ω, an inductance of 33 mH, and a capacitance of 10 nF. The voltage divider equation will yield a complex value, which should be converted to magnitude and angle for analysis. The user plans to compare calculated values with oscilloscope measurements to find percentage error.
dwn
Series RLC - Band Pass Filter[/B]
R = 2700Ω
Vi = 5 Vpp
C = 10 nF
L = 33 mH
I need to find the voltage across the resistor for different frequencies.
w = 2pi*ƒ
V = R*Vi / (jwL + 1/jwC+R)
This is from a lab experiment. How can I use the source voltage, R and ƒr to find the voltage across R at different frequencies.
-----update -----
sorry about that. new values added above.
R = 2700Ω
Vi = 5 Vpp
w = 2pi*ƒ
You haven't given all the information required: What are the values of L and C?
Your relevant equations are indeed relevant. You've correctly written a voltage divider equation which will give you the voltage across the resistor for values of Vi and f. Of the the result will be a complex value. You might try reducing it to magnitude and angle (polar) form. In the lab, what device (test equipment) was used to read the output voltage?
We used an oscilloscope to read the measured values, now I have to calculate the data with the given data for comparison. Then find the percentage error.
Okay. So you'll have recorded values for the waveform peaks, thus the voltage magnitudes, for various frequencies. You can use your voltage divider equation to calculate the voltage and determine the theoretical magnitude values. Again, you might want to reduce the formula to a magnitude version.
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
