Set closed in Y, but not in superset of Y, X?
  • Thread starter Thread starter Vespero
    Closed Set
Vespero
Let Y be a subset of X. Give an example where a set A is closed in Y but not closed in X.
A set is closed if its complement is open.
A set is open if for every element x0 of the set, there exists an E > 0 such that U(x0;E) = {x|d(x,x0)< E} is contained in the set.
I tried various combinations of X and Y, usually leaving X as the real numbers. I started with X as the reals, and Y as some open or closed interval in the reals, but had no luck. I know that a closed set in the reals (here, X) is a set that contains its boundaries, so I am looking for a set that is missing at least one of its boundary points (and is thus non-closed in X) but is closed in Y. However, I can't seem to find a proper Y such that such a set is closed in Y. While reading through some texts online, I came across the claim that the set A = [0,1] ∩ Q of rational numbers between 0 and 1 (inclusive) is closed in the space of rational numbers, but is not closed in the real numbers. However, I can't see why this is true. The complement of A in Y is (0,1) ∩ {irrationals}, but if we choose a point y from this set, it doesn't seem like there is an E > 0 such that every point within a distance E from y is irrational.
As for A = [0,1] ∩ Q being non-closed in X, its complement there is (-∞,0)U((0,1)∩Q)U(1,∞). (0,1)∩Q is not open in the X, so neither is its union with the open intervals shown.
I just don't understand why it is closed in Y.
how about considering when A \cap Y = Y
clearly A is closed in Y, though you should be able to come up with a case when it i not closed in X...
If A ∩ Y = Y, the complement of A in Y is the null set, which is simultaneously open and closed, I believe. This tripped me up, but I guess that all that matters is that the complement is open for the set to be closed, correct? If that's true, then A and Y could both be the same open interval/region in R or RxR, right?
Yes, (0,1) is open in the real numbers. (0,1) is closed considered as a subset of (0,1).
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
