Set Theory Proof: A∩B=Ø implies C∩D=Ø
dainty77
Hey guys!
I am new to this forum but saw the helpful posts on set theory proofs and wondered if I could finally get some help with this problem:
Suppose A, B, C, and D are sets with A⊆C and B⊆D. If A∩B=Ø then C∩D=Ø.
This is a biconditional so I have to prove it both ways correct?
Any help would be greatly appreciated!
Where's the biconditional? I only see an if then, not an if and only if. What work have you done?As stated, the conjecture is false. Are you sure you have the sense correct in terms of which sets are subsets of some other set?
My mistake, it is an "if then" statement.
As I previously said, the conjecture as written is false. For example, consider sets of fruits. Let A={apple}, B={banana}, C={apple, orange}, and D={banana, orange}. With this, A⊆C, B⊆D, and A∩B=Ø, but C∩D={orange}, which is not the null set.
Likes 1 person
Wow, the example of using fruit really helped clarify it a lot more. Thank you so much!
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
