songoku
- 2,490
- 393
- Homework Statement
- The diagram below shows galvanometer. A coil of wire is wound around a circular iron core which is placed between two magnets with circular surface such that the magnetic field (indicated by arrows) on the surface of iron core is directed perpendicularly onto the surface and of the same magnitude across the surface of iron core as shown in diagram.
When a constant current flows in the coil, the needle will be deflected to angle ##\theta## from the vertical direction. Sketch a graph to show the variation of torque ##\tau## on the soft iron core due to magnetic force acting on the coil with the angular displacement ##\theta## of the needle as the needle rotates from zero to ##\theta_0##. Explain
- Relevant Equations
- ##\tau## = F . d
I know the torque will be zero when the deflection is zero and will be maximum when the angular displacement is θ0 but how to determine the exact shape of the graph?
Thanks
