Shear and bending moment diagram problem
The discussion revolves around a problem involving shear and bending moment diagrams, specifically questioning the validity of a point load at Support B and its implications for calculating reaction forces Va and Vb. The original poster is unsure if Vb can be set to -15 kN. Responses clarify that a point load can exist at Support B, but it does not equal 15 kN; instead, it contributes to the overall reaction forces. To confirm the calculations, it's recommended to take moments about a point not used in the initial analysis. The key takeaway is that understanding the role of point loads at supports is crucial for accurately determining reaction forces in structural analysis.
futureengineer
I have attached a diagram
14 + Va -32 + Vb -15=0??
or Vb=-15?
The reason why I cannot attempt this problem is that I'm not sure whether it is valid that there can be a point load at Support B or whether they are implying that Vb=-15kN.
After I get Va and Vb I know what to do :)
This is the only issue I need to clarify.
Cheers
-Diagram
OOPS I forgot to attach diagram. Cheers
You can have a point support load at B, but it's not equal to 15.
Chet
Yes you can have a point load over the reaction point. It just adds its value to that obtained from the other loads. In every case of calculating reactions, you should check it, for example by taking moments about a point not used in the original analysis. In that case you do not need help in answering the question.
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
10K
