Shell Method Example: Finding Volume Around Axes and a Line
In summary, the x-axis has a value for fathers that is determined by the equation: R(x)=\sqrt{x}, while the y-axis has a value for fathers that is determined by the equation: R(y)=3. Around the x-axis, there is a region where the right hand side resists at x=3, which is the furthest away. Around the y-axis, the right hand side resists at y=3 and y^2=x. Around the line x=3, the R(y) value is 3-y^2. For c), around the x=3 line, the R(y) value is determined by solving for y^2. For d),
stripedcat
44
I don't need the answers or the problems worked out I'm asking something more basic. This is just an example problem.
\(\displaystyle y=\sqrt(x),y=0, x=3\)
a) Around the x-axis
\(\displaystyle R(x)=\sqrt{x}, r(x)=0\)
I understand the R to be the value fathers from the x-axis, and the r value to be the closer one to the x-axis.
b) Around the y-axis
\(\displaystyle R(y)=3\)
This is because the right hand side of the bound region resists at x=3, which is the furthest away.
\(\displaystyle r(y)=y^2\)
This is what I'm not clear on. How as this determined?
c) Around the line x=3
R(y)3-y^2
Not sure on that one either?
I would first begin by graphing the area to be revolved:
Now, if we are going to revolve about the $x$-axis, we may choose the disk method, where the volume of an arbitrary disk is:
\(\displaystyle dV=\pi r^2\,dx\)
where:
\(\displaystyle r=y=\sqrt{x}\)
hence:
\(\displaystyle dV=\pi x\,dx\)
Adding up all the disks, we get the volume:
\(\displaystyle V=\pi\int_0^3 x\,dx=\frac{\pi}{2}\left[x^2\right]_0^3=\frac{9\pi}{2}\)
Now, we could have chosen to use the shell method, where the volume of an arbitrary shell is:
\(\displaystyle dV=2\pi rh\,dy\)
where:
\(\displaystyle r=y\)
\(\displaystyle h=3-x=3-y^2\)
hence:
\(\displaystyle dV=2\pi y\left(3-y^2\right)\,dy=2\pi\left(3y-y^3\right)\,dy\)
Adding up all the shells, we get the volume:
\(\displaystyle V=2\pi\int_0^{\sqrt{3}} 3y-y^3\,dy=2\pi\left[\frac{3}{2}y^2-\frac{1}{4}y^4\right]_0^{\sqrt{3}}=\frac{9\pi}{2}\)
Can you try the other axes of revolution now?
I'm actually totally fine and I know the formulas to do the equations for shell, disk, and washer, and the arc length one as well.
What I'm not so clear on is how to get the values to solve for them unless its rotating around the x-axis as in a.
In this particular case, I can see when going around the y axis, the R, being the larger of two radius, is 3, as that x=3 line is the 'furthest' point from the y-axis that is being rotated around.
My understanding for the r(y) is that since that curve is y=sqrt(x), by solving for y I get y^2 = x, so that's the 'closer' point to the y-axis that is being rotated around.
For c) which is around the x=3 line, in order to get the R(y) value, you are moving to the left (thus, in a negative direction) from the x=3 line until you reach the curve, which we have already established is y^2, so that's where I think the 3-y^2 comes from. r(y) in this case is zero since we're going around the x=3 line
for d) its going around the line x=6, which is +3 from the x=3 line it ends up being (3+3-y^2) or 6-y^2 to find the distance from the x=6 line to the curve.
Is this the correct way of thinking about it?
FAQ: Shell Method Example: Finding Volume Around Axes and a Line
1. What is the Shell Method?
The Shell Method is a mathematical technique used to find the volume of a solid of revolution. It involves integrating the product of the circumference of a cylindrical shell and the height of the shell.
2. When is the Shell Method used?
The Shell Method is used when the cross-section of a solid of revolution is perpendicular to the axis of revolution, and when the boundaries of the solid can be expressed as functions of the axis of revolution.
3. How do you set up the Shell Method?
To set up the Shell Method, you first need to determine the axis of revolution, the boundaries of the solid, and the equations of the functions that represent the boundaries. Then, you need to find the radius and height of the cylindrical shells. Finally, you set up the integral using the formula V = ∫ 2πrh dx.
4. What is the difference between the Shell Method and the Disk Method?
The Shell Method and the Disk Method are both used to find the volume of a solid of revolution, but they use different cross-sections. The Shell Method uses cylindrical shells, while the Disk Method uses circular disks.
5. Can the Shell Method be used to find the volume of any solid of revolution?
No, the Shell Method can only be used when the cross-section of the solid is perpendicular to the axis of revolution. If the cross-section is not perpendicular, then a different method, such as the Washer Method, must be used.
