SHM: Deriving x = A cos(wt) & Intuitive Understanding
  • Thread starter Thread starter Oz Alikhan
    deriving Shm
The discussion focuses on deriving the equation x = A cos(wt) for simple harmonic motion (SHM) and clarifying the relationship between amplitude and the radius of a pendulum. The initial confusion arises from a potentially incorrect diagram that does not align with the expression. The user seeks to understand how the expression x = A cos(wt) is derived from the relationship x = r cos(wt), where r represents the radius. Clarification is provided that the notation used in the diagram and text may be misleading, as "A" refers to both a point and a numerical value representing the radius. Overall, the discussion emphasizes the need for clear diagrams and notation in understanding SHM concepts.
Oz Alikhan
Short story:
How does one go about to derive x = a cos(wt)? The way it is derived in my book is from the "SHM Diagram" file that I have uploaded but it seems that the diagram is incorrect as it does not correspond to the expression. Also, why is the Amplitude in the expression constant when the radius of a pendulum is also constant which implies that x has to be also constant?More of the story:
I have seen the expression, x = a cos(wt) derive other expressions through calculus but I have not seen how this expression itself is derived from.
In the file "SHM Text" that I have uploaded, I understand up to the part of x = rcos(wt) and where that corresponds to the diagram. However shortly after that, the book states that for pendulums r = A therefore the expression becomes x = A coswt. I cannot see why or how or even where that corresponds to the diagram. I have tried drawing diagrams from that expression but it never seems to match the book's diagram.
Thanks for the help :smile:
The notation is unfortunate. In the picture they appear to have labeled two points "A" and "B" but, in the text, then use "A" as if it were a number. It looks like they are thinking of the point "A" as corresponding to the point (A, 0) where A is now a number, the distance from the origin to the point "A". In that case, number, A, is the radius of the circle: r= A.
Likes 1 person
Makes sense now. Thanks a lot :smile:
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
