I Shooting an electron past a positive nucleus (trajectory)
When an electron is shot horizontally past a proton, the trajectory can be analyzed as a two-body problem, though it simplifies to a one-body problem with the proton fixed. The distance of closest approach can be derived using conservation of energy and angular momentum principles. The relationship between scattering angle and trajectory can be expressed using hyperbolic parameters, specifically the formulas L² = γb²/a and E = γ/2a, where γ = e²/m. For further understanding, references to Rutherford scattering provide additional insights into the behavior of charged particles in such interactions. This analysis highlights the importance of classical mechanics in understanding particle trajectories in electromagnetic fields.
phantomvommand
TL;DR Summary
An electron is shot horizontally. There is a proton located somewhere else, but not in the horizontal path of the electron. Is there a distance of closest approach, and how do you derive it? A physical explanation would be appreciated too. Feel free to use any variables.
It's straightforward as a one-body problem but a little more subtle as a two-body problem. For the one-body (fixed proton) scenario it's enough to conserve energy and angular momentum about the proton. If you want the scattering angle/trajectory then you can relate these to the hyperbolic parameters ##a## and ##b## with the standard formulae ##L^2 = \gamma b^2 / a## and ##E = \gamma / 2a## [where ##\gamma = e^2/m##]; the proton is at the far focus.
Likes berkeman and PeroK
You could search for Rutherford scattering. There's quite a bit online about this.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
