Short table of integrals (.tex file) will include pdf of output.
In summary: Instead, it simply causes the thread to be bumped to the top of the list and becomes more difficult to find.In summary, summarizing content is a valuable skill.
DrWahoo
53
Code:
\documentclass[12pt]{article}
\usepackage{graphicx}
\addtolength{\textwidth}{1.5in}
\addtolength{\hoffset}{-1.in}
\addtolength{\textheight}{2.0in}
%\addtolength{\voffset}{-1.68in}
\addtolength{\voffset}{-0.8in}
\newcommand {\rreal}{\mbox{$R\!\!\!\!\!l\,\,\,\,$}}
\newcommand{\graphspace}{\vspace{2in}}
\newcommand{\eqnspace}{\hspace{.1in}}
\newcommand{\toppageoneexam}{\vspace{-.4in} \mbox{ } \hspace{-.6in}
\parbox[t]{7.8in}
{\noindent {\bf Name:} \hspace{.01in}
$\underline{\mbox{\hspace{3.5in}}}$\ \ {\bf Section:} \underline{\hspace{.5in}}  }}
%\newcommand{\toppageexam}{\vspace{-.4in} \parbox[t]{7.5in}
%{\noindent {\bf Name:} \hspace{.01in}
%$\underline{\mbox{\hspace{3.5in}}}$\\ }}
\newcommand{\toppageexam}{\vspace{-.6in}  \hspace{-.6in}
\parbox[t]{6.5in}
$\underline{\mbox{\hspace{3.5in}}}$ \ \ {\bf Section:} \underline{\hspace{.5in}} }}
\include{macros}
\begin{document}\toppageoneexam%Integrals
\ee
\bc {\bf A short table of integrals} \ec
\be
 \item $A$ a constant \  \imp \ $\int Adx = Ax + C$,
 \item $n \neq 0, 1$ \ \imp \ $\int x^n dx = \frac{x^{n+1}}{n+1} + C$
 \item $\int \frac{dx}{x} = log(x) + C$; \ind \ind Integration by parts: $\int u dv = u v - \int v du $
 \item $\int e^{ax} dx = \frac{1}{a}e^{ax} + C$; \ind \ind
   Substitution: $u = u(x), \ \int u du = \int u(x) u'(x) dx $
 \item $\int xe^{ax} dx = e^{ax}(\frac{x}{a} - \frac{1}{a^2})  + C$
 \item $\int x^2e^{ax} dx = e^{ax}(\frac{x^2}{a} - \frac{2x}{a^2} +
\frac{2}{a^3})  + C$
 \item $\int log(a x) = xlog(a x) -x + C$
 \item $\int x log(a x) = \frac{x^2}{2} log(a x) -\frac{x^2}{4} + C$
 \item $\int \frac{dx}{a^2 + x^2} = \frac{1}{a} arctan(\frac{x}{a}) +
C $
 \item $\int \frac{dx}{a^2 - x^2} = \frac{1}{2a} log(\frac{x+a}{x-a})
+ C$
 \item $\int \frac{dx}{\sqrt{a^2 - x^2}} = arcsin(\frac{x}{a}) + C $
 \item $\int \frac{dx}{\sqrt{x^2 - a^2}} = log(x + \sqrt{x^2 - a^2}) + C$
 \item $\int \frac{dx}{\sqrt{a^2 + x^2}} = arcsinh(\frac{x}{a}) + C $
 \item $\int sin(ax) = - \frac{1}{a} cos(a x) + C$
 \item $\int cos(ax) = \frac{1}{a} sin(a x) + C$
 \item $\int tan(ax) = \frac{1}{a} log(sec(a x))  + C$
 \item $\int cot(ax) = \frac{1}{a} log(sin(a x))  + C$
 \item $\int sec(ax) = \frac{1}{a} log(tan(a x)+sec(a x)) + C$
 \item $\int csc(ax) = -\frac{1}{a} log(csc(a*x)+cot(a*x)) + C$
 \item $\int x \ cos(ax) = \frac{x \ sin(a x)}{a} + \frac{cos(a x)}{a^2}
+ C$
 \item $\int x \ sin(ax) = \frac{sin(a x)}{a^2} - \frac{x \ cos(a x)}{a}
+ C$
\end{document}
  • Integrals.pdf
If anyone wants me to add one to the code and the output, I will gladly do so. Would be nice to have a very comprehensive list so user could check their u-sub, partial fractions, and intg by parts. I think the washer and shell method is left out way to often as well.
All code and output is free to use. I will never post anything that I won't allow reproduction of. Thus feel free to copy and edit code as you prefer. Again, we are all here to help one another! If you need anything in particular, feel free to post up a question and I will help to the best of my ability along with others.
Hello DrWahoo,
Please keep in mind MHB rule #1 states:
No bumping. Bumping a thread is posting a reply to that thread solely to raise its profile and return it to the top of the active threads list. This is forbidden at MHB. If you want to draw attention to an unanswered thread, then post something of value such as further progress. It is also forbidden to bump one thread by drawing attention to it in a different thread.
We discourage such posting behavior because such a post adds no value or content to a thread.
FAQ: Short table of integrals (.tex file) will include pdf of output.
1. What is a short table of integrals?
A short table of integrals is a list of commonly used integrals and their corresponding solutions. It is often used as a reference guide for mathematicians and scientists to quickly solve integrals in their work.
2. How is a short table of integrals organized?
A short table of integrals is usually organized in alphabetical order by the variable used in the integral. It may also be categorized by the type of integral, such as trigonometric or logarithmic.
3. What is the purpose of including a .tex file?
A .tex file is a source document used in the typesetting system LaTeX. Including a .tex file allows for easy customization and formatting of the short table of integrals, making it more visually appealing and easier to use.
4. Can I use the short table of integrals in my research or homework?
Yes, the short table of integrals can be used as a reference in your research or homework. However, it is important to properly cite the source of the table.
5. Is the output in the form of a PDF file?
Yes, the output of the short table of integrals is usually in the form of a PDF file. This allows for easy sharing and printing of the table without affecting its formatting.
