Short webpage title: Calculating Electric Field and Force from Two Charges
  • Thread starter Thread starter dgl7
The discussion focuses on calculating the electric field and force from two charges positioned on a horizontal axis. The participant attempts to determine the electric field strength at a point above the charges using the formula E=kQ/r^2 but struggles with the correct distance for point p. They realize that the electric field is a vector quantity, requiring consideration of both magnitude and direction for each charge. Confusion arises regarding the correct approach to add the electric fields from both charges, emphasizing the need to account for their directional components. The conversation highlights the complexities involved in vector addition when dealing with electric fields.
dgl7
Two charges create an electric field--electric field strenght at a point above h.fiel
Two charges are located on a horizontal axis. The Coulomb constant is 8.98755x10^9 Nm^2/C^2.
a) Determine the electric field at p on a vertical axis as shown in the attachment. Up is the positive direction. Answer in units of V/m.
b) Calculate the vertical component of the electric force on a -3.1e-6C charge placed at point p. Answer in units of N
a) E=kQ/r^2
b) F=Eq
a) I'm fairly certain I know how to find the field strength from the two charged particles, if point p was directly on the field and in the center.
E=E1+E2
E=k/r^2(Q+q)
E=8.98755e9/3^2(2.2e-6+2.2e-6)
E=4393 V/m
But I think I also need to take into account that p is above the two particles, but now I'm stuck...
b) I think this part would be easier, I just can't do it since I haven't gotten the answer to part a.
F=Eq
F=E(that would be found in part a)(-3.1e-6)
Hi dgl7! :smile:
dgl7 said:
E=k/r^2(Q+q)
That's correct, if p was on the x-axis, you would use r = 3 for each charge, and add.
Instead, use r = the actual distance between p and each charge.
That will give you the force, so remember force is a vector, and add the two vectors.
AHHH that makes sense. Thanks very much!
Ok nope. Nevermind, I'm still confused.
This is what I've been doing and attempting:
E=Eleft+Eright
E=kQleft/r^2+kQright/r^2
(r=r and Qleft=Qright)
E=2kQ/r^2
E=2*8.98755e9*2.2e-6/(1.8^2+3^2)
E=3230.818627 V/m
Not sure what I'm doing wrong.
The electric field is a vector,
so the electric field from each charge has the magnitude kQ/r2, but it also has a direction.
The direction is different for each charge, so you can't just add the magnitudes, can you? :smile:
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
