Other Should I Upgrade Graduate Certificate Into Second Masters Degree?
The discussion centers on whether to upgrade a Graduate Certificate in Systems Engineering to a full master's degree, considering the implications for career advancement and the financial support from the employer. The individual already holds two degrees in Electrical Engineering and is weighing the necessity of a second master's degree against the potential benefits. Key points include the requirement to retake classes due to credit expiration and the lack of job postings specifically requiring two master's degrees in the field. Many participants suggest that while additional qualifications can be beneficial, practical experience and knowledge often hold more weight in hiring decisions. The consensus leans towards evaluating personal career goals and considering if the time spent on the degree could be better utilized elsewhere, especially since the employer is willing to cover most costs. Ultimately, the decision hinges on the perceived value of the degree in the current job market and personal career aspirations.
YoshiMoshi
I have two Electrical Engineering Degrees, Bachelor of Science and a Master of Engineering.
I'm almost done with a Graduate Certificate in Systems Engineering. Which is 4 classes.
I can upgrade the Graduate Certificate in Systems Engineering to a full blown masters (10 classes). Should I? My company would pay for most of it. It's hard to turn down free stuff.
Food for thought:
  1. I would need to take an additional 6 classes, 4 systems engineering, 1 project management, 1 graduate math class, to upgrade the certificate to a degree
  2. I already took a project management class and graduate math class at another university when I earned my first Masters degree. Because it was more than 6 years ago, I can't transfer the credits over from the first masters to a second masters. My current university does not allow credit by examination for graduate classes. So I can't "test out" of these two classes. So I would have to take these two classes again a second time, despite getting excellent grades from the first time I took them. I'm 110 % against retaking classes I got As in just because it was more than 6 years ago.
  3. Once the classes from my graduate certificate are more than 6 years old, they "expire". Meaning I won't be able to pursue the masters degree without retaking the 4 classes from the certificate because they would be "expired". Despite getting good grades.
I work in industry as an electrical systems engineer. Should I upgrade a systems engineering graduate certificate to a masters degree? I already have a bachelors and masters in electrical. Would getting two masters degree help my career as an engineer? I have to make a decision soon.
Thanks for any help in academic advising!
Would completing this degree mean you would probably get a raise in your current position? An expanded job assignment with a corresponding raise?
When you look at job openings at other companies, does it seem like the extra degree will make a difference? At least in my line of work as an EE (R&D on embedded systems), once you have the basic degrees, your work experience and knowledge (tested in interviews) matter the most.
In my case, no, not in my current position. I wouldn't get a penny raise. When I look at job postings at other companies, I haven't come across a single one that mentions two master degrees.
Why do people get two master degrees?
No, you look for posts that read "MS EE required" and posts that separately read "MS Systems Engineering required." And see whether the number of posts in the second category would justify spending the time in getting a MS Systems Engineering.[ETA: Longer Answer]
* Sometimes a second master’s is useful if you shift directions in your career. For example, if you have a MS EE and are content doing hands-on technical work, you’re fine with the single degree. But if you later want to switch away from hands-on technical work, and migrate towards management or business roles, then getting an MBA may help advance your career.
* With respect to degrees in two separate technical fields, that depends strongly on how flexible hiring managers are in your particular fields of interest. You’ll often hear the advice: “Once you’ve worked for X years, it’s your track record that matters, not your degree.” That’s true to a certain extent, but not completely. I’ve cited my own personal example before: I have a PhD Physics. And I have had a lot of experience in designing and building complex mechanical apparatus. At one time, a recruiter (who had worked with me before) approached me for a position as a patent agent for a client primarily involved with mechanical inventions. At the time I already had a well-established track record as a patent agent. The recruiter thought I’d be a good fit, and forwarded my resume to the client. But the client responded, “Candidate must have a BS ME.” So even though I had probably more mechanical engineering experience than a fresh BS ME, even though I had a well-established track record as a patent agent, and even though my recruiter was pushing to have the client at least talk to me, the client held firm on the degree requirement, and wouldn’t even consider me. But, since I had plenty of other prospects, I felt no need whatsoever to get a BS ME. :wink:
* In your case, you have an MS EE and are working as an electrical systems engineer. If you wanted to (or had to) find a systems engineering job at another company, you’ll be fine as long as the job posts don’t specify “MS Systems Engineering required”. If they specify something more flexible along the lines of “MS EE or MS Systems Engineering preferred. Candidates with other degrees having appropriate experience will be considered.”, you’re OK.
* In your specific case, since your company is willing to foot the bill for the second master's, cost is not a consideration. The question then is your time. The second master's certainly won’t do any harm, and might help (and learning new stuff can be an end in itself, even if review of some previous material is involved). The question then is, "What other activity would you spend your time on, if you don’t pursue the second master's?" And it doesn’t have to involve professional advancement, just something satisfying and of value to you.
I'm going to make this one quick since I have little time. Background: Throughout my life I have always done good in Math. I almost always received 90%+, and received easily upwards of 95% when I took normal-level HS Math courses. When I took Grade 9 "De-Streamed" Math (All students must take "De-Streamed" in Canada), I initially had 98% until I got very sick and my mark had dropped to 95%. The Physics teachers and Math teachers talked about me as if I were some sort of genius. Then, an...
Bit Britain-specific but I was wondering, what's the best path to take for A-Levels out of the following (I know Y10 seems a bit early to be thinking about A-levels, but my choice will impact what I do this year/ in y11) I (almost) definitely want to do physics at University - so keep that in mind... The subjects that I'm almost definitely going to take are Maths, Further Maths and Physics, and I'm taking a fast track programme which means that I'll be taking AS computer science at the end...
After a year of thought, I decided to adjust my ratio for applying the US/EU(+UK) schools. I mostly focused on the US schools before, but things are getting complex and I found out that Europe is also a good place to study. I found some institutes that have professors with similar interests. But gaining the information is much harder than US schools (like you have to contact professors in advance etc). For your information, I have B.S. in engineering (low GPA: 3.2/4.0) in Asia - one SCI...
