Should Integration by Parts Be Used on Functions Like \( x \cdot y(x) \)?
  • Thread starter Thread starter Fluidman117
    Integration
Fluidman117
I want to take an antiderivative of a function with respect to x. But in addition the function includes a term y (x) that is a function of x itself. Do I have to apply the reverse power rule also to y(x) also? The integral can be seen as an indefinite.
A=\int x*y(x)*dx
I think I should just apply the reverse power rule to x. So:
A= \frac{x^{2}}{2}*y(x) + C
A=\int x*y(x)*dx
You can answer your own question---and that is the best way to learn! Just try it out on some examples. What do you get if you use your formula on the function ##y(x) = x^2##? What happens if you use your formula on ##y(x) = 1/x^2##? Are you getting correct results?
What you are looking for is something called integration by parts.
Okay, then I believe I was mistaken. It seems that I also need to apply the reverse power rule to ##y(x)##.
So an example:
##y(x)=2*x##
A=\int^{2}_{1} x*y(x)*dx=\int^{2}_{1} x*2*x*dx
A=\left|2\frac{x^{3}}{3}\right|^{2}_{1}=4.6667
Is this correct?
I also looked up the integration by parts and it seems that in the above example it was possible to do without the integration by parts. But can someone give a good example why and when is it necessary to turn to the integration by parts technique?
Try \displaystyle\int_0^\pi x \sin x\,dx or \displaystyle\int_0^1 x e^{-x}\,dx.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
