B Shouldn't the refracted ray be along the boundary here?
  • B
  • Thread starter Thread starter Physical_Fire
The discussion centers on the behavior of light as it passes from a glass cube into a liquid, specifically regarding the angles of incidence and refraction. The critical angle for the glass-liquid boundary is stated as 63°, leading to confusion about whether the refracted ray should travel along the boundary or undergo total internal reflection. It is clarified that total internal reflection can occur when the angle of incidence is equal to or greater than the critical angle. The participants discuss the visualization of the ray's path and the conditions under which refraction ceases. The conversation emphasizes understanding the transition between refraction and total internal reflection at the critical angle.
Physical_Fire
A glass cube is held in contact with a liquid and a light ray is directed at a vertical face of the cube. The angle of incidence at the vertical face is 42° and the angle of refraction is 27° as shown in the diagram. The light ray is totally internally reflected for the first time at P. Complete the diagram to show the path of the ray beyond P to the air and calculate the critical angle for the glass-liquid boundary.
Here is the image: .
In the answer scheme, the critical angle is given as 63°. If it is 63°, shouldn't the refracted ray travel along the boundary and not totally internally reflect, as total internal reflection occurs when the angle of incidence is greater than the critical angle? How is it possible when they are the same angle?
Science news on Phys.org
Welcome to PF.
Can we assume that the point P is the same as the point X ?
Yes, it was a typo from my part; I apologize. I fixed it.
your question is about the refraction of light from the glass to the liquid and for the critical angle you gotta get an angle of incidence that makes the refractive angle 90 so yes they are supposed to go with the boundry
But in the image, the ray doesn't go along the boundary, and I have trouble visualizing it. How should it be drawn?
Physical_Fire said:
...as total internal reflection occurs when the angle of incidence is greater than the critical angle?
Just make it "greater or equal" if that limiting case confuses you. When you approach it from below, it is when the refraction disappears. When you approach it from above, it is when the refraction appears.
Thread 'Simple math model for a Particle Image Velocimetry system'
Hello togehter, I am new to this forum and hope this post followed all the guidelines here (I tried to summarized my issue as clean as possible, two pictures are attached). I would appreciate every help: I am doing research on a Particle Image Velocimetry (PIV) system. For this I want to set a simple math model for the system. I hope you can help me out. Regarding this I have 2 main Questions. 1. I am trying to find a math model which is describing what is happening in a simple Particle...
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
