MHB Show deg of minimal poly = dimension of V
  • Thread starter Thread starter catsarebad
    Dimension
catsarebad
if V = C_x for some x belongs to V then show
deg(u_L) = dim(V)
here,
L: V -> V linear operator on finite dimensional vector space
C_x = span {x, L(x), L^2(x),....}
u_L = minimal polynomial
my thought:
since C_x = V, it spans V. if it spans v, then degree of minimal poly that we somehow obtain from L should be dim(V). i dunno.
i can't figure out how to connect C_x and L with minimal poly.
If $C_x = V$ for some $x$ (such an $x$ is clearly non-zero), then consider the smallest $m$ for which:
$\{x,Lx,\dots,L^mx\}$ is linearly dependent.
By the definition of linearly dependent, this means we have $c_0,c_1\dots,c_m$ not all 0 with:
$c_0x + c_1Lx +\cdots + c_mL^mx = 0$.
By the minimality of $m$, $c_m \neq 0$.
Thus $L$ satisfies the polynomial (since $x$ is non-zero):
$p(x) = c_0 + c_1x + \cdots + c_mx^m$
Therefore (since $p(L) = 0$) we conclude that $\mu_L|p$.
But if $L^mx$ is a linear combination of $\{x,Lx,...,L^{m-1}x\}$ then any higher power of $L$ is likewise a linear combination of these (you may want to supply an inductive proof of this..up to you).
Thus $V$ = span($C_x$) = span($\{x,Lx,...,L^{m-1}x\}$).
and we have $m = $ dim$(V)$.
The above shows that deg($\mu_L$) $\leq$ dim($V$).
Now argue that $\{x,Lx,...,L^{m-1}x\}$ is linearly independent, to show that:
deg($\mu_L$) $> m - 1$.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
