A Show Lagrangian is invariant under a Lorentz transformation without using generators
binbagsss
TL;DR Summary
considering directly coordinate transformations and how to consider boost-translation
This is probably a stupid question but, I want to show that a Lagrangian written in field theory is Lorentz invariant WITHOUT using the Lorentz transformation representation / generators. I know we know that a Lorentz scalar is automatically Lorentz invariant, but, I want to show this by considering the coordinate expressions directly.
I.e to plug in :
##t’=\gamma (t-\frac{vx}{c^2}),##
##x’=\gamma(x-vt) ##(1)
and expanding out the fields.
So I expand out ##L[\phi(x,t), \partial_{mu}\phi(x,t)] ->L'[\phi(x',t'), \partial_{mu}\phi(x',t')]##
(where I just wrote ##\phi(x,t),## rather than ##x^{\mu}## just because of the transformation written as (1)).
1 )And then I think, for everything to be consistent, it should then come out that for ##L ##to be Lorentz-invariant ##\phi## would have to satisfy the known transformation laws for field theory (Since, in contrast to a Galilean invariant Lagranigan, where one has to uniquely decipher the way a wavefunction needs to transform in order to get Galilean invariance for the Lagrangian), the way fields transform are already predetermined).
(So a Lorentz transformation is defined by: ##g'^{\mu \nu}=\Lambda^{\mu}_{\alpha}\Lambda^{\nu}_{\beta}g^{\alpha \beta}=g^{\mu \nu}##, and where a vector must satisfy: ##x'^{\mu}=\Lambda^{\mu}_{\alpha}x^{\alpha}##). So, I think, I would expect to find that for ##L## to be Lorentz invariant, this should give an expansion for ##\phi## in terms of ##\Lambda^{\mu}_{\alpha}## expanded out for a boost- it would agree with ##\phi## in terms of ##\Lambda^{\mu}_{\alpha}## expressed in terms of boost generators and expanded out
2) How would I show that Lorentz boost and translation do not commute for a Lagrangian in field theory when we have Lorentz scalars so everything is invariant w.r.t boost translations and boosts . I want to consider performing a boost then a translation and vice versa..
I showed you how to do that in the non-relativistic case,
https://www.physicsforums.com/threa...slation-on-a-wave-function-or-fields.1066552/
As I pointed out there, it's important to understand how the transformations of the group (or infinitesimally, from the algebra) act on the wave function. So under a boost or translation, one has for a scalar field that ##\phi'(t',x') = \phi(t,x)##. So that's not going to give you information about the (non)commutativity of the algebra. That's why I explained in post #3 how these transformations act on the wavefunction. The same goes for the relativistic operators on the scalar field ##\phi(t,x)##.
Also, you should transform the derivative in the Lagrangian. That transforms as a covector.
If you don't respond to comments in your own topics, then it will be a hard time helping you. Good luck.
i went back to the old thread and replied there 2 days ago which has not been replied to
I asked a question here, probably over 15 years ago on entanglement and I appreciated the thoughtful answers I received back then. The intervening years haven't made me any more knowledgeable in physics, so forgive my naïveté ! If a have a piece of paper in an area of high gravity, lets say near a black hole, and I draw a triangle on this paper and 'measure' the angles of the triangle, will they add to 180 degrees? How about if I'm looking at this paper outside of the (reasonable)...
Thread 'Relativity of simultaneity in actuality'
I’m attaching two figures from the book, Basic concepts in relativity and QT, by Resnick and Halliday. They are describing the relativity of simultaneity from a theoretical pov, which I understand. Basically, the lightning strikes at AA’ and BB’ can be deemed simultaneous either in frame S, in which case they will not be simultaneous in frame S’, and vice versa. Only in one of the frames are the two events simultaneous, but not in both, and this claim of simultaneity can be done by either of...
