MHB Show, that (7+5√2)^(1/3)+(7−5√2)^(1/3) is an integer
  • Thread starter Thread starter lfdahl
    Integer
The discussion focuses on proving that the expression \( a = \sqrt[3]{7+5\sqrt{2}} + \sqrt[3]{7-5\sqrt{2}} \) is an integer. The solution involves expanding \( (1 \pm \sqrt{2})^3 \) using the binomial theorem, which results in \( 7 \pm 5\sqrt{2} \). This leads to the conclusion that \( \sqrt[3]{7 \pm 5\sqrt{2}} \) equals \( 1 \pm \sqrt{2} \). Therefore, adding these two results yields \( a = 2 \), confirming that \( a \) is indeed an integer. The discussion highlights the elegance and simplicity of the solution.
lfdahl
MHB
Let $a = \sqrt[3]{7+5\sqrt{2}} + \sqrt[3]{7-5\sqrt{2}}$. Show (without the use of a calculator), that $a$ is an integer.
Mathematics news on Phys.org
we have a is real
cube both sides to get using $(x+y)^3= x^3+y^3 + 3xy(x+y)$
$a^3= 7+5\sqrt{2} + 7-5\sqrt{2}+ 3 (\sqrt[3]{7+5\sqrt{2}})(\sqrt[3]{7-5\sqrt{2}})a$
$= 14 + 3a$
hence $a^3+3a-14=0$
by rational root theorem 2 is a root
hence $a^3-4a + 7a-14 =0$
or $(a-2)(a^2 + 2a) +7(a- 2) = (a-2)(a^2+2a+7)=0$
so a = 2 or $a^2+2a+7=0$ which gives complex roots
so a = 2 as a is real
now I leave some one to prove that 2 is integer
My solution:
[sp]Expand $(1 \pm \sqrt2)^3$ binomially to get $$(1 \pm \sqrt2)^3 = 1 \pm3\sqrt2 + 6 \pm2\sqrt2 = 7 \pm 5\sqrt2.$$ So $1 \pm \sqrt2 = \sqrt[3]{7\pm 5\sqrt2}$, and $\sqrt[3]{7 + 5\sqrt2} + \sqrt[3]{7 - 5\sqrt2} = (1 + \sqrt2) + (1 - \sqrt2) = 2.$
[/sp]
we have a is real
$= 14 + 3a$
hence $a^3+3a-14=0$
Well done, kaliprasad! A clear and sharp solution indeed! Thankyou for your participation!(Yes)
- - - Updated - - -
Opalg said:
My solution:
[/sp]
This is a suprisingly short and elegant way to "crack the nut". Thankyou, Opalg, for your participation!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
