Show that the vector has zero divergence
The discussion focuses on demonstrating that the vector v = (r-hat)/(r^2) has zero divergence and zero curl, indicating it is both solenoidal and irrotational for r not equal to 0. Participants share their attempts to use the del operator in spherical coordinates, noting difficulties in calculating divergence while successfully determining that curl(v) equals zero. Questions arise about posting LaTeX code correctly and the role of metric coefficients in the calculations. Suggestions for resources include links to guides on LaTeX usage and vector calculus references for understanding coordinate systems. The conversation emphasizes the importance of proper formatting and understanding the mathematical principles involved.
dizewarrior
v = \frac{\hat{r}}{r<sup>2</sup>} (not sure why formatting isn't working?)
v = (r-hat) over (r squared)
has zero divergence (it is solenoidal) and zero curl (it is irrotational) for r not equal to 0
div(V) = (d/dx)V_x + (d/dy)V_y + (d/dz)V_z
I used del operator in spherical (the r component being (d/dr)) and it didn't seem to work?
for curl i was able to get curl(v) = 0
I've tried converting v to cartesian and using the cartesian del operator but it didn't work either
I'm stuck at this point =\
dizewarrior said:
v = \frac{\hat{r}}{r^2} (not sure why formatting isn't working?)
Don't use the BBcode tags within LaTeX mark-up.
Also, if you're going to use LaTeX, use it for the whole equation instead of bits and pieces. It's easier to type, and it'll look better.
Also, you might need to refresh your screen to get the LaTeX to work.
thanks everyone!
few questions though,
1) where can I find a guide on posting LaTeX code on the forums?
2) does the 1/(r^2) * (r^2 * v_r): does the r^2 come from metric coefficients?
dizewarrior said:
thanks everyone!
1) See https://www.physicsforums.com/showthread.php?t=386951 to get started.
2) I'm not sure what you mean by metric coefficients. These factors show up for similar reasons as to why the volume element in spherical coordinates is r2 sin(theta). A vector calculus book should explain it in the section about grad, div and curl in different coordinate systems. Maybe even the wiki page I linked to earlier explains it?
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
