MHB Show that there are points Q,R on C such that the triangle PQR is equilateral.
  • Thread starter Thread starter lfdahl
    Points Triangle
lfdahl
MHB
Let $C$ be a smooth closed curve (no corners) in the plane with a convex interior,
and $P$ a given point on $C$. Show that there are points $Q,R$ on $C$ such that the
triangle $PQR$ is equilateral.
Mathematics news on Phys.org
Suggested solution:
Let an angle of $60^{\circ}$ revolve counter-clockwise about $P$, with initial position of one of the arms tangent to $C$ at $P$. The intercepts of the two arms are initially $0$ and some $q > 0$. Turn the angle until the other arm becomes tangent to $C$, and the intercepts are now some $r > 0$ and $0$. Hence the difference of the intercepts changes from: $0-q < 0$ to $r-0 > 0$. By continuity there is a position of the two arms $\overline{PQ}, \overline{PR}$ where $|PQ| = |PR|$, hence the triangle $PQR$ is equilateral.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
