MHB Show x³y+y³z+z³x is a constant
  • Thread starter Thread starter anemone
    Constant
For real numbers x, y, z satisfying x+y+z=0 and xy+yz+zx=-3, the expression x³y+y³z+z³x is proven to be a constant. The proof involves substituting z with -x-y, simplifying the expression, and demonstrating that it does not change with different values of x and y. Various algebraic manipulations show that the resulting expression remains invariant under the given conditions. The discussion emphasizes the importance of these constraints in establishing the constancy of the expression. Ultimately, the expression x³y+y³z+z³x holds a fixed value under the specified conditions.
anemone
MHB
POTW Director
Show that for all real numbers $x,\,y,\,z$ such that $x+y+z=0$ and $xy+yz+zx=-3$, the expression $x^3y+y^3z+z^3x$ is a constant.
Mathematics news on Phys.org
We have (given)
$x+y+z=0 \cdots(1)$
$xy+yz+zx=-3\cdots(2)$
From (1)
$(x+y+z)^2 = x^2 + y^2 + z^2 + 2(xy +yz + zx) = 0$
or $x^2 + y^2 + z^2 + 2(-3) = 0$
or $x^2 + y^2 + z^2 = 6\cdots(3)$
Further from (1)
$x+y = -z\cdots(4)$
$y+z = -x\cdots(5)$
$z+x = -y\cdots(6)$
Now let us prove that
$x^3y+ y^3 z + z^3 x = xy^3 + yz^3 + zx^3\cdots(7)$
to prove the same
$x^3y+ y^3 z + z^3 x - (xy^3 + yz^3 + zx^3)$
$= (x^3y - xy^3) + (y^3z - yz^3) + (z^3 x - zx^3)$
$= xy(x^2 - y^2) + yz(y^2 - z^2) + zx(z^2 - x^2)$
$=xy(x+y)(x-y) + yz(y+z)( y-z) + zx(z+x)(z-x)$
$=xy(-z)(x-y) + yz(-x) (y-z) + xz(-y) (z-x)$ using (4), (5), (6)
$= - xyz(x-y) - xyz(y-z) - xyz(z-x)$
= 0so (7) is true
Now $(x^2 + y^2 + z^2)(xy + yz + zx) = 6 * (-3) $ putting values from above
Or $x^3y + x^2yz + zx^3 + xy^3 + y^3 z + y^2zx + z^2yx + yz^3 + z^3 x = 18$
or $(x^3y + y^3 z + z^3x) + (xy^3 + yz^3 + zx^3 ) + (x^2yz + xy^2z + xyz^2) = - 18$
or $(x^3y + y^3 z + z^3x) + (x^3y + y^3z + z^3x ) + (x^2yz + xy^2z + xyz^2) = - 18$ (from (7)
or $2(x^3y + y^3 z + z^3x) + xyz(x+y+z) = - 18$
or $2(x^3y + y^3 z + z^3x) + xyz. 0 = - 18$ from (1)
or $2(x^3y + y^3 z + z^3x)= - 18$ from (1)
or $(x^3y + y^3 z + z^3x) = - 9$
Which is a constant
Hence proved
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
