Showing Superposition Principle with Time-Dependent Schrödinger Equation
To demonstrate that the combination of two solutions of the time-dependent Schrödinger equation is also a solution, one must substitute the linear combination c1*psi1 + c2*psi2 into the equation. This process involves verifying that the resulting expression satisfies the equation for arbitrary constants c1 and c2. The superposition principle is key to this proof, as it allows for the addition of solutions. Many resources simply state this as a fact without detailed explanation. Ultimately, the solution requires direct substitution and verification within the framework of the Schrödinger equation.
blueyellow
Show that, if psi1 and psi2 are both solutions of the time-dependent Schr¨odinger
equation, so is c(subscipt1) psi1 + c(subscript2) psi2 (where c1 and c2 are arbitrary constants).
every source I've consulted so far just states it as a fact. i know its somthing to do with the superposition principle but how do i literally show what they ask? its only a 2 markk que
thanks in advance
Just plug that combination into the Schrodinger equation and show it satisfies the equation.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
