I Showing that B has no discontinuities at the surface
The discussion centers on the continuity of the magnetic field ##\mathbf{B}## at the surface of a magnetic dipole distribution characterized by magnetization ##\mathbf{M}##. It is established that the magnetic field ##\mathbf{H}## has no discontinuity in the volume, while the surface field ##\mathbf{H}^{S}## and the magnetization ##\mu_0 \mathbf{M}## exhibit discontinuities at the surface. The participants explore the implications of these discontinuities for the continuity of the magnetic field ##\mathbf{B}##, concluding that the normal component must remain continuous due to the equation ##\mathbf{B}=\mathbf{H} + \mu_0 \mathbf{M}##. However, questions arise regarding the tangential component's continuity and the roles of charge density ##\rho## and surface charge density ##\sigma## in relation to ##\mathbf{M}##. The discussion highlights the complexities of magnetostatics, particularly in cases involving surface currents and singularities.
Mike400
Consider a magnetic dipole distribution in space having magnetization ##\mathbf{M}##. The potential at any point is given by:
##\displaystyle\psi=\dfrac{\mu_0}{4 \pi} \int_{V'} \dfrac{ \rho}{|\mathbf{r}-\mathbf{r'}|} dV' + \dfrac{\mu_0}{4 \pi} \oint_{S'} \dfrac{\sigma}{|\mathbf{r}-\mathbf{r'}|} dS'=\psi^{V}+\psi^{S}##
The ##\mathbf{H}## field is:
##\displaystyle\mathbf{H}=\dfrac{\mu_0}{4 \pi} \int_{V'} \rho \dfrac{\mathbf{r}-\mathbf{r'}}{|\mathbf{r}-\mathbf{r'}|^3} dV' + \dfrac{\mu_0}{4 \pi} \oint_{S'} \sigma \dfrac{ \mathbf{r}-\mathbf{r'}}{|\mathbf{r}-\mathbf{r'}|^3} dS'=\mathbf{H}^{V}+\mathbf{H}^{S}##
The ##\mathbf{B}## field is:
##\mathbf{B}=\mathbf{H} + \mu_0 \mathbf{M}=\mathbf{H}^{V} + \mathbf{H}^{S} + \mu_0 \mathbf{M}##
##\mathbf{H}^{V}## has no discontinuity.
##\mathbf{H}^{S}## has discontinuity of ##\mu_0 \mathbf{M} \cdot \hat{n}## at the surface ##S'##
##\mu_0 \mathbf{M}## has discontinuity of ##\mu_0 \mathbf{M}## at the surface ##S'##
From these knowledge, how shall one deduce that ##\mathbf{B}## is continuous at the surface?
My try: (I am getting a contradiction)
We need to show that ##\mu_0 \mathbf{M} \cdot \hat{n}+\mu_0 \mathbf{M}=0##, i.e. ##\mathbf{M} \cdot \hat{n}= -\mathbf{M}##
Since the surface could be oriented at any angle w.r.t. ##\mathbf{M}## at the surface, this is a contradiction. Where am I going wrong?
I guess what you mean is that due to
$$\vec{\nabla} \cdot \vec{B}=0$$
##\vec{B}##'s normal component at the surface must be continuous.
I'm also a bit lost what ##\rho## and ##\sigma## have to do with ##\vec{M}##. Without a surface magnetization (which is a bit unusual; I'm not sure, where one would find such a thing in nature) the correct solution of magnetostatics of a (hard) ferro magnet is
$$\vec{H}=-\vec{\nabla} \phi$$
with
$$\phi(\vec{x})=-\vec{\nabla}_x \cdot \int_{\mathbb{R}} \mathrm{d}^3 x' \frac{\vec{M}(\vec{x}')}{4 \pi |\vec{x}-\vec{x}'|}.$$
Likes Dale
I know that and can be simply deduced from the equation ##\mathbf{B}=\mathbf{H} + \mu_0 \mathbf{M}=\mathbf{H}^{V} + \mathbf{H}^{S} + \mu_0 \mathbf{M}##. But should the tangential component of ##\vec{B}## must be continuous too? The equation shows a discontinuity in the tangential component.
vanhees71 said:
I'm also a bit lost what ##ρ## and ##σ## have to do with ##\vec{M}##
##ρ=-\nabla \cdot \mathbf{M}## and ##σ=\mathbf{M} \cdot \hat{n}##
The tangential component of ##\vec{H}## can have a singularity due to a surface current, and usually also ##\vec{B}## has one there too.
The standard example is a homogeneously magnetized body. The magnetization is equivalent to a current density
$$\vec{j}_{\text{m}}=\vec{\nabla} \times \vec{M},$$
and in this approximation that's a surface current density.
E.g., take a homogeneously magnetized sphere of radius ##a## around the origin of the coordinate system. Then we can write (with ##r=|\vec{x}|##)
$$\vec{M}(\vec{x})=M \vec{e}_3 \Theta(a-r).$$
The curl is
$$\vec{\nabla} \times \vec{M}=-M \vec{e}_3 \times \vec{\nabla} \Theta(a-r).$$
Now
$$\vec{\nabla} \Theta(a-r)=\frac{\mathrm{d}}{\mathrm{d} r} \Theta(a-r) \vec{\nabla r} = -\frac{\vec{x}}{r} \delta(a-r)=-\frac{\vec{x}}{a} \delta(a-r)$$
and thus
$$\vec{j}_{\text{m}}=\frac{M}{a} \vec{e}_3 \times \vec{x} \delta(r-a),$$
i.e., you have ##\delta##-function like singularity across the surface of the sphere which means that there's a surface-current density.
It's a good example to calculate the magnetic displacement ##\vec{H}## and the magnetic field ##\vec{B}## for this example, which is analytically solvable. Then the concepts of charge and current densities as well as their singular cases, i.e., surface charge and current densities become clear.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Thread 'Does Poisson's equation hold due to vector potential cancellation?'
Imagine that two charged particles, with charge ##+q##, start at the origin and then move apart symmetrically on the ##+y## and ##-y## axes due to their electrostatic repulsion. The ##y##-component of the retarded Liénard-Wiechert vector potential at a point along the ##x##-axis due to the two charges is $$ \begin{eqnarray*} A_y&=&\frac{q\,[\dot{y}]_{\mathrm{ret}}}{4\pi\varepsilon_0 c^2[(x^2+y^2)^{1/2}+y\dot{y}/c]_{\mathrm{ret}}}\tag{1}\\...
