A SiC Vertical MOSFET channel length modulation
  • A
  • Thread starter Thread starter bonkgeek
The discussion focuses on the representation of channel length modulation in vertical MOSFETs, particularly how increased drain voltage affects performance. Unlike lateral MOSFETs, vertical MOSFETs have the drain positioned away from the channel, which influences current flow and pinch-off behavior. The speaker presents a vertical MOSFET design, highlighting its unique geometry where current flows vertically from source to drain. Vertical MOSFETs are primarily utilized in SiC power applications due to their superior voltage withstand capabilities. Understanding these differences is crucial for effective application in power electronics.
bonkgeek
Hello , Thank you readind me
I wonder how to represent the reduction in channel length(pinch off seen in lateral MOSFET) for vertical mosfets due to the increase in drain voltage because the drain is at the back, away from the creation of the channel position.
Welcome to PF.
Your diagrams only seem to show lateral MOSFETs. Can you show a typical vertical MOSFET geometry and say where it is used? I have not used them yet.
Thanks
I am presenting a vertical MOSFET, where the drain is situated in a different plane compared to the source and gate. In this configuration, the current flows vertically from the source to the drain.
This design contrasts with the lateral MOSFET, which you can learn more about by referring to examples available HERE https://www.mks.com/n/mosfet-physics.
Vertical MOSFETs are predominantly used in SiC power MOSFETs, as their vertical structure enables the component to exhibit strong voltage withstand capability.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
