Sigma [sin(1/x)] for x=1 to ∞: Converge or Diverge?
The discussion centers on determining the convergence or divergence of the series Sigma [sin(1/x)] from x=1 to infinity. Participants suggest using the limit comparison test with the harmonic series, noting that L'Hospital's rule yields a limit of 1, indicating divergence. The integral test is also proposed, showing that the integral of sin(1/x) from 1 to infinity is not finite. Ultimately, the consensus is that the series diverges. The analysis confirms that Sigma [sin(1/x)] does not converge.
Phoenix314
I need to determine whether Sigma [sin(1/x)] for x=1 to x=infinity converges or diverges. I have a feeling that it diverges, but I don't know how to prove it.
Thanks
Use the limit comparison test, with the harmonic series \sum_{n=1}^{\infty} \frac{1}{n}
Thanks Cyclovenom, I took \frac{sin(1/x)}{1/x} and did the limit as x approaches infinity with L Hopital's rule, but I got 0, so doesn't that make it inconclusive?
Thanks
Your result throught L'Hospital is wrong, it will be 1, and sice 1 > 0, and this harmonic series diverges, then sin (1/x) diverges.
Alternatively you could consider \lim_{x \rightarrow 0} \frac{\sin x}{x} = 1
hello there
just use the integral test
\sum_{n=1}^{\infty} \sin{\frac{1}{n}} \le \int_{1}^{\infty}\sin{\frac{1}{x}}dx \not< \infty
its not finite and so does not converge
steven
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
