Signal processing approach to stydy the brain
Different approaches in neuroscience, including neurobiophysics, computational neuroscience, and engineering, offer unique insights into brain function. Engineering, particularly in signal processing, has practical applications such as noise reduction and diagnostics, while also contributing to fundamental research on brain mechanisms. The methods used in these fields are often complementary, making it difficult to determine which is the most promising for understanding the brain. Institutions like Stanford are conducting significant research in brain imaging that could enhance understanding in this area. Overall, the integration of applied and basic research perspectives is crucial for advancing knowledge of brain function.
Neuroni
I have sought information about different approaches(fields) to neuroscience and how they differ in terms of understanding how the brain works. I'm interested to learn more about neurobiophysics, computational neuroscience and engineering perspectives. In engineering especially about brain signal analysis and brain signal processing.
I understand that engineering perspective contains broad range of application related stuff and for example signal processing can have practical purposes like noise reduction from signals and diagnostic applications. But I'm interested to know if there is any science
in this approach in a sense that you can study and explain how the the brain works and make new discoveries with these signals and systems methods? Because I'm interested in both the applied and the basic research side, this is important question for me.
Lastly which one of these three fields do you think is best(most promising) path for understand the brain?
If someone could help me with this i would really appreciate it.
Thanks for your help.
Engineering perspective would be the best for you
There are lots of ways to look at the brain and they all have something to offer. It depends on the level of abstraction you're interested in. Most of the different methods are complementary so one isn't necessarily more promising than another.
up up
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
