Engineering Signals in discrete form (scaling, shifting etc.)
The discussion revolves around understanding signal manipulation in digital signal processing, specifically how to handle the transformation of a discrete signal x[n]. The user is attempting to find x[n-1], 2x[n-1], and -2x[n-1]+3, expressing confusion about shifting and scaling operations. There is a consensus that shifting involves zero padding and that the addition of a scalar to a vector should be approached element-wise. The conversation highlights the challenges posed by poorly defined homework questions and the need for clarity in instructional materials. Overall, the thread emphasizes the importance of understanding the underlying principles of signal manipulation.
jisbon
Given that x[n] = [5 1 7 9 4 3], where 5 is x[0].
Find x[n-1] , 2x[n-1] and -2x[n-1]+3
Attempting this question without any guidance from my professors unfortunately as they did not teach this bit. Searched online and also there aren't many questions like this.
From what I know,
(I) Having n-1 means you should shift right by 1, which means x[0] is now equals to 0? So x[n-1] = [0 5 1 7 9 4 3]?
ii) 2x[n-1] is simply a magnitude scaling of part one, so is it simply just 2x[n-1] = [0 10 2 14 18 8 6]?
(iii) -2x[n-1]+3. Is this simply again a magnitude scaling by -2 of part 1? Not sure how to do the +3 function though. Any help will be appreciated here :)
Do you know if x[n] is periodic?
Also which class is this for and what are some topics you just recently covered in class, or maybe which book are you following? If the problem came from the textbook, then what's the name of the chapter it's coming from? I'm trying to get more context.
Likes FactChecker
I'm not sure, it wasn't stated. Digitial signal processing, and the question came from a worksheet, not a textbook.
Well, that's as good an answer as any. But they didn't really tell you how to deal with x[0], did they? Some poorly defined questions have no answer. OTOH, I like your guess (which we call "zero padding" in the engineering world). You might also drop the 3 at the end, since in your answer you've increased the dimension of the vector, which is sometimes ok, and sometimes not. IDK.
jisbon said:
Homework Statement:: Given that x[n] = [5 1 7 9 4 3], where 5 is x[0].
Relevant Equations:: -
Well they're asking you to add a vector to a scalar, in my interpretation. Again, undefined. But I like your approach of doing it element by element, nothing else makes much sense to me.
Sometimes the questions asked depend on the material previously presented; i.e. they are assuming that you will do things the way they showed you previously. Other times the instructors are lazy or idiots and they ask poorly worded questions. Writing good HW/test questions is often harder than it appears.
Thread 'PLL - How to find all the gains of a PI corrector and fix Ki ? MATLAB'
Hello everyone, it's not really for my homework (because I'm not at school anymore) but I'm new and I don't know how to start a new forum. I've never done automatic before and I need help. I have a 2nd ordre PLL on MATLAB, with an NCO and a PI corrector; the PLL works via the Mid/End algorithm (that's part is ok). I need to find the link between the theoretical formulas and their values in the code to find the value of the gain Ki, and possibly that of Kp if it's not correct. Unfortunately...
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
