Significance of kinematic and dynamic viscosity
Kinematic viscosity is defined as the ratio of dynamic viscosity to density, serving as a convenient term in fluid mechanics. It simplifies equations, particularly in the context of the Reynolds number, where \mu/\rho terms appear frequently. Both viscosities measure how momentum is diffused through a fluid, with kinematic viscosity specifically acting as a diffusivity constant. The discussion highlights the analogy between the heat equation and the Navier-Stokes equations, emphasizing the role of kinematic viscosity in momentum transfer. Understanding these concepts is crucial for analyzing fluid behavior in various applications.
Waqar Amin
It is stated that kinematic viscosity is the ratio of dynamic viscosity to density. can anyone elaborate it further that what are the uses of both types of viscosities and why we differentiate them.does dynamic viscosity reates with static fluid?
It is really just a term of convenience. Oftentimes, the equations of fluid mechanics are manipulated such that you end up with \mu/\rho terms, so it is simply much easier to carry around a \nu instead of a fraction. This is commonly seen with the Reynolds number, which has a \mu/\rho term in it.
then how kinematic viscosity is termed as momentum diffusivity, i m very confused with these terms.
Well, as with any sort of viscosity, it is really a measure of how momentum is diffused through a fluid. If you are familiar with the heat equation, you should notice some analogs between it and the Navier-Stokes equations.
The heat equation:
\frac{\partial \phi}{\partial t} = c^2\nabla^2 \phi
The incompressible Navier-Stokes equation:
\frac{\partial \mathbf{v}}{\partial t} + \mathbf{v}\cdot\nabla\mathbf{v}=-\frac{1}{\rho}\nabla p + \nu\nabla^2\mathbf{v} + \mathbf{f}
The heat equation is a simplified version of the diffusion equation that describes the diffusion of basically any quantity through a material. In heat transfer, c^2=\alpha=\frac{k}{\rho c_p} is the thermal diffusivity.
In the Navier-Stokes equations, notice that the \nu\nabla^2\mathbf{v} term takes the same form, only the N-S equations are a momentum balance, so the kinematic viscosity, \nu, is essentially a diffusivity constant that describes how momentum diffuses through the medium. In other words, it describes one particle's ability to affect the momentum of the adjacent particles.
i have understand. thanxx for your help boneh3ad. :)
I have Mass A being pulled vertically. I have Mass B on an incline that is pulling Mass A. There is a 2:1 pulley between them. The math I'm using is: FA = MA / 2 = ? t-force MB * SIN(of the incline degree) = ? If MB is greater then FA, it pulls FA up as MB moves down the incline. BUT... If I reverse the 2:1 pulley. Then the math changes to... FA = MA * 2 = ? t-force MB * SIN(of the incline degree) = ? If FA is greater then MB, it pulls MB up the incline as FA moves down. It's confusing...
Hi. I noticed that all electronic devices in my household that also tell time eventually lag behind, except the ones that get synchronized by radio signal or internet. Most of them are battery-powered, except my alarm clock (which runs slow as well). Why does none of them run too fast? Deliberate design (why)? Wrong temperature for quartz crystal? Decreasing battery voltage? Or just a coincidence?
