Significant digits including only one zero
The discussion centers on determining significant digits in a physics problem involving deceleration from 60 km/h to 0 km/h over 1.2 seconds. It clarifies that the final result should have two significant digits, as the 0 km/h can be disregarded in this context. The conversation also addresses how to report the speed of a stationary toy, concluding that 0 m/s is appropriate since it indicates no movement with precision. The distinction between 0 km/h and 0 m/s is emphasized, highlighting the importance of context in significant digit usage. Overall, the thread provides clarity on significant digits in various scenarios.
alingy1
The problem asks us to find deceleration from 60km/h to 0km/h in 1,2 seconds.
The speed formulas
I know how to apply the formula. However, in the problem, it is written 0km/h. How many significant digits is that? How many significant digits should i have in this problem for the final result?
You should have 2 in your answer as acceleration is the change in velocity (i.e. 60km/h in this case). The 0km/h can be ignored in the case of significant digits :smile:
Thank you
Thanks that's what I wanted to know. The zero is confusing. Also, for my lab report, I have to jot down the speed of a small toy according to the time passed. At the beginning, the toy is not moving. Should I put 0m/s or the number of significant digits put for the other data, since we can't really be sure the toy is not moving very very slightly?
Thanks again.
If it's not moving initially, 0 m/s will be fine.
"Not moving" implies zero km/h with extreme precision. That is different from 0km/h. What would your answer be if the original question was looking for 60km/h to 1km/h?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
