Silicon and Germanium semiconductor mixtures used in component manufacturing?
Silicon and Germanium mixtures, potentially combined with other elements like gallium or arsenide, could enhance the robustness of electronic components. The discussion highlights the importance of understanding semiconductor chemistry and the potential applications in quantum computing. A foundational knowledge of semiconductor theory and quantum mechanics is essential for exploring these advancements. Resources such as textbooks and online courses are recommended for deeper learning. The exploration of these semiconductor mixtures could lead to significant innovations in electronic and quantum technologies.
akerkarprashant
TL;DR
Si + Ge + ? + ? =
Can Silicon and Germanium semiconductors mixture (chemical reaction) with some other chemical elements (if required) assist in creating new and existing robust electronic components?
Si + Ge + ? + ? =
Can this assist in quantum computing?
Mentor note: Changed the level from "A" to none.
You indicated an A (Advanced) level for this post, indicating that you are at a post-graduate level or beyond. You should have a good idea how semiconductor devices work. What other elements are routinely added? What do you think the answers to your questions are?
Likes jsgruszynski
Possible other elements could be gallium, arsenide etc.
Thanks & Regards,
Prashant S Akerkar
I am guessing from your reply that you have no significant background in either semiconductors or quantum theory. I suggest you start by reading the Wikipedia article Semiconductor, and then following the links it contains to the relevant sub-topics (Doping, e.g.). There are many online references as well, or you can pick up an inexpensive used copy of this excellent textbook: Sze, Physics of Semiconductor Devices.
To understand quantum computing, you need a solid course in quantum mechanics. You might check out the offerings from MIT Open Courseware.
Likes Vanadium 50 and berkeman
I am trying to understand how transferring electric from the powerplant to my house is more effective using high voltage. The suggested explanation that the current is equal to the power supply divided by the voltage, and hence higher voltage leads to lower current and as a result to a lower power loss on the conductives is very confusing me. I know that the current is determined by the voltage and the resistance, and not by a power capability - which defines a limit to the allowable...
  • · Replies 24 ·
14K
  • · Replies 25 ·
